Question about HP Photosmart C6180 All-In-One InkJet Printer
C6180 how do i select the photo tray instead of the paper tray so that I can just print on a 4x6 instead of a whole sheet. my image is in iphoto, not on a memory card or camera
  • bearlythere Nov 09, 2008
    Do you mean for me to take my 4x6 photo paper and load it in the tray where I normally load letter sized paper? I tried to do that, unsuccessfully. The printer does not seem to be able to load it. I thought it might because I can load envelopes. Maybe the photo paper is too stiff. I was wondering if I could somehow redirect the HP printer to print from the smaller photopaper tray. Perhaps this tray only works with memory cards from a camera. Anyway, I got around the problem by printing a 4x6 on a letter sized paper (wasting most of the letter sized photo paper). I would like to be able to just print one 4x6 at a time on 4x6 paper.
    Thanks for trying to help.
  • Anonymous Jan 03, 2009
    I can not print a photo from the 4X6 photo tray.I have the photoes stored on my hard drive.
  • 37 Answers
Load the paper in the tray
go to file menu then page setup.
select HP all-in-one printer
choose the paper size, orientation and scale percentage
chick ok then choose print from the file menu
configure the print settings suited for your project.
click print
make sure that you choose the correct paper type before you click print.
Posted on Nov 09, 2008
  • technetwork2015 Nov 10, 2008
    there is a photo tray dedicated just for your 4x6 photos. raise the output tray until it does not go further then pull out the phototray. insert your photo paper then slide the guide inward.
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
How to load 4X6 photo paper
hi
  • Turn on the Epson 875DC and the attached computer. Make sure the cable between the two devices is securely in place.
  • Step 2 Remove any paper that is in the printer's feeder tray. Place the 4x6 photo paper printable side up in the tray, with the support sheet at the bottom of the stack of photo paper. Adjust the paper guides so they are pressed against the margins of the paper.
  • Step 3 Open the photos to be printed in your computer software program of choice. When you are ready to print the photos, click on the "File" link at the top of the window, then choose "Print." Click on "Properties" and select "4x6" for the paper size and "Photo Paper" under the paper type. Click "OK" to close the "Properties" window, then click "OK" again to print the photos.
  • Jul 02, 2010 | Brother MFC255CW All-in-One InkJet Printer
    I can not get the 4x6 paper to feed into the printer during the printing process. the paper shoots through and the printer. screen says the paper is incorrect size. i am using kodak ultra premium photo...
    Kindly place the paper in the photo paper tray and then place a photo on the scanner glass of the paper and press copy.Correspondingly,if you are printing from computer make sure that you select 4X6 in the printing properties or preferences while printing the pictures. Your issue will be solved.Keep me posted if you are facing any problems.
    Dec 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
    Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
    1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
    2. Click Start and then click Control Panel .
    3. Click Printers and Faxes .
    4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
    5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
    6. Make sure that the Source is box is set to Photo tray .
    7. Click the Borderless Printing box if borderless prints are desired.
    8. Click Apply and then click OK .
    9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
    Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
    Can't print on photo paper from iphoto
    When running a piece of photo paper through the printer you must first remove the stack of regular paper from the tray and run only one photo paper at a time. Thank you, Dana
    Oct 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Instructions on printing a 4 x 6 card or photo on my HP 4280 All in One printer. How to I set up the printer?
    At the printer:
    1. Remove any paper from the input tray
    2. Put a few sheets of 4x6 (10 or so) in the same tray
    3. Adjust the paper holder bar so that the 4x6 paper stays straight in place. The holder bar was holding the 8x11 paper in place.
    On the computer:
    Open a picture
    Seect [File] [Print]
    Select the photo printer from the list
    Cick on [Preferences]
    See the paper type? select photo paper
    See the paper size? Select 4x6
    Quality (Best)
    [OK]
    [PRINT]
    Sep 28, 2009 | HP Office Equipment & Supplies
    Printing Photos on Photo Paper
    Ensure u are placing the paper in the photo tray..
    if u r printing from the memory card which is inserted in the printer..ensure that the PHOTO BUTTON on the printer is on..
    You can also try to reset the printer by going to the SETTINGS/TOOLS menu (RENCH SYMBOL) and then look for the Factory Restore (Might be under "Preferences")
    Sep 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Printing from iphoto - photos are not 4x6 and not borderless
    wat pc do u have? are u using mac? if ur using microsoft try these:
    go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
    Mar 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
    HP Photosmart D7360-Won't print from photo tray
    You have to push in the photo tray~. Push until you hear it click...then it will print from the print tray and in turn, you will be able to print photos unto your glossy photo paper instead of the letter size paper.
    Oct 29, 2007 | HP Photosmart D7360 All-In-One InkJet...
    HP Photosmart C6180 All-In-One InkJet Printer Logo
    282 people viewed this question
    Ben Johnson
