Manifold on pump cracked
SOURCE: no pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
SOURCE: I REQ A NEW PUMP MANIFOLD CRACKED HAS ABOUT 5 MINUTES ON IT
Im looking for one too....If i find one i'll let you know....if u find one please also let me konw where i can find it. Thanks
[email protected]
SOURCE: I have a DeVilbiss pressure washer, Serial#
THE PUMP FITS THE MOTOR and the pump i always use is a ROYALPUMP made in Italy and they are long lasting and easily serviced ,any of the Italian pumps are good
SOURCE: excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Testimonial: "thanks, funoldman i will check that out.....good info"
thank you.
