Question about HP Computers & Internet
Has HP pavilion dv5-1004ax fitted with wreless support
  • 3 Answers
Yes it has atheros wireless, but I don't recomend buying one the're a AMD CPU and are very jumpy, I don't recomend buyng one though you can buy the next model up with an Intel CPU stay away from AMD ok buddy! I have A dv5-1004ax and i might try and sell it to buy the next model up with intel as well intel is has twice the amount of power and strength/capatablities.
Posted on Apr 14, 2009
What CPU 'chips' can be fitted to the HP Pavilion slimline magnetite motherboards ?
according to HP's compatibility list..
CeleronM 420 (Y) 1.6 GHz
  • 533 MHz front side bus
  • Socket 479
    May 25, 2014 | Washing Machines
    My hp pavilion does not see the dvd drive I just installed
    Chaange the data cable if the it pata , the jumper select cs other wise fit tightly.if not wor again change it newly .If it is sata change newly or fit tightly.
    Nov 21, 2010 | HP Pavilion A730N (PJ510AA) PC Desktop
    I want to connect my HP pavilion notebook dv1000 by firewire
    You should be able to get a firewire card to fit you computer. A standard pc card should fit a HP. There are two separate kinds of PC cards. There are the standard and the express versions. Make sure you get the standard version, because express is mostly for Dell. You may want to go to HP and confirm this by looking at the support section for your computer. As far as what type of firewire card, get what you think you will need. There isn't much difference between different brands.
    Feb 09, 2010 | HP Pavilion dv1000 Notebook
    Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
    Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
    If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
    Jan 15, 2010 | Dell Inspiron 1525 Laptop
    Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
    just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
    Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
    Will new micro atx boards fit inside of a hp 4550z case?
    Yes i think you will be ok as i can see and your old motherboard is microatx but i strongly recommend you to change case because is not only about motherboard.You will need and better and new power supply and if you want to build a good system with air flow for not overheating your new cpu and other hardware i strongly recommend you to change and chassis!!You can find a "nice" case with $50-$70 bucks if you dont want to spend money on case,but you will need power supply for sure
    Jan 07, 2010 | HP Computers & Internet
    Printer port for my new hp pavilion dv7?
    You should be able to use a parallel to usb converter heres one in the link. There hard to find most are usb to parallel but this should work.
    http://www.usbtech.com.au/product.php?productID=GW-K200
    Mar 23, 2009 | HP Pavilion dv7-1132nr Notebook PC
    Hp pavilion dv6700 amd turion 64x2 mobile...need ethernet driver
    by doesn't fit, do you mean gives you a microsoft verification error, such as "this driver is not verified by Microsoft."?
    If that is the case, let it install anyhow. HP knows better than Microsoft whether the drivers will work.
    Jan 01, 2009 | HP Pavilion DV6700Z Notebook
    Does this Hp Pavilion zv5000 Laptop Batteries Fits for Hp Pavilion ze Series Laptop
    hp pavilion zv5000 battery Compatible with Code:
  • Compaq 346970-001
  • Compaq Hstnn-db02
  • Compaq Hstnn-ub02
  • Compaq pp2100
  • Compaq pp2200
  • Hp 346970-001
  • Hp Compaq Hstnn-ib04
  • Hp dp390a
  • Hp dp399a
  • Hp Hstnn-db02
  • Hp Hstnn-ub02
  • so it is campatible with it~~
  • Nov 21, 2007 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
    Computers & Internet Logo
    82 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
