Question about Koss KS4192 System
Audio from tv
I have an LG 60pyd tv, that I hooked up to the KS4192. When I have a dvd in, the sound is awesome and sounds like I am in a theater...as it should. Although, when I have just the tv on, the sound does not go above, about 80...my tv by itself goes louder. How do I get the same sound like playing a dvd, when watching just tv?
  • rahenry321 Nov 10, 2008
    I think I miswrote my problem. When I have the dvd in and playing in the home theater system, I get great sound. When I try to watch regular tv,using the home theater system sound, I do not get the same sound and I cannot get the sound up any higher than 80 on the home theater system. My hd tv setup manual book says to hookup blue, green, and red wires to the componet line 1, and then the red and white to the audio componet line 1.
  • rahenry321 Nov 13, 2008
    Problem fixed, thanks to the master...masers1004. Thank you so very much.
  • 34 Answers
It sounds like you have the red,white rca cables hooked from the back of the tv to the red,white input on the stereo or the same connection from you hd sat box or hd cablebox. In order to get the same sound quality from tv service as you do on dvd is to run a fiber optic cable or digital coax audio cable from you hd sat box or hd cablebox to your stereo which means no red,white rca cables at all, take them out. Also once you do that you must be on a hd channel to get equal sound quality of a dvd movie. I know on some hd cable or hd sat boxes you have to go in and set them up to dolby digital as well after you hook it up the way I was explaining. Try this and I hope this is helpful.
Posted on Nov 09, 2008
  • Brandon M. Nov 10, 2008
    So how do you have your tv sound hooked to stereo system? Also do you have hd cable or hd sat box in your setup? If you do then you need to run a fiber optic cable from either your hd cable box or hd satellite box to your stereo depending which service you have for tv. You don't need red and white audio cables if you have hd service through either provider. I looked up the specs online for your system and it shows that you have a fiber optic in and a digital coax in on the back of your stereo. Either of those connections would give you the same sound quality of a dvd movie as long as you are watching hd programming.
    One more comment I forgot to add on to my last reply is that your volume should be done on your stereo not on your tv. Just wanted to make that clear cause some people try to turn volume up using tv volume bar and that actually would turn up stereo sound but that is a analog method which isn't the best quality based on your current system. How loud does your stereo get on dvd is it louder than 80?
Can i hook up my rca dvd home theater system to my tv so i can get sound from watching tv channels which is hooked up to dish satellite? is this possible?
Yes it is possible.
All you need to do is run a cable from the Audio Out on your TV to the Audio In of the DVD.
Then you will be able to get the sound of TV channels from the DVD speakers.
Mar 10, 2011 | RCA RTD317 Theater System
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
I purchased aRCA 250W DVD Home Theater System with
do you have a set of cables coming from the tv AV out to your home theater system? if not you need to you can use coax out or anolog out either one
Dec 03, 2009 | Televison & Video
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Audio problems with surround speaker system on
I have had the same problem on my home theater maybe you should try to wiggle the speaker cord it could be loosly hooked up to your home theater
Nov 22, 2008 | LG Televison & Video
LG Home Theater System LHT754 no sound
All you are currently doing is getting sound OUT from the LG HT system. If you want sound from your cable or satellite, you have to run a seperate audio cable into the back of the LG system. If you are running a cable line straight into the TV you need to run an audio cable OUT of the TV so you get sound via the LG system.
Jun 17, 2008 | Audio Players & Recorders
Hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Mar 21, 2008 | LG LHT734 System
Lg LH-D6230. How to hook up? PLEASE HELP! NO INSTRUCTION MANUAL!!
je kan met 2 tulp aansluitingen via de dvd speler audio out naar je tv gaan en dan de instelling aux van de dvd speler gebruiken zo kan je surround tv kijken
Jan 16, 2008 | LG LH-D6230 System
Koss KS4192 System Logo
239 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
