Question about OKI C5400dn Led Printer
OKI 5400DN It does not seem to be printing blue properly. The ink cartridge (yellow) looks empty but it has not asked me to order or replace the cartridge.
  • 114 Answers
Just check the cyan leeds head and clean it, or check the cyan drum.
Posted on Jan 17, 2007
The color of my print is very pink and yellow with no blue
If your printer has 3 colored ink cartridges, your cyan (blue) cartridge is empty. Replace it with a new one. If your printer has just one colored ink cartridge, the blue section of it is empty. Replace the cartridge with a new one. You'll find the correct cartridge (normally a number) in the owners manual and/or on the cartridge itself. See the owners manual for instructions on where the cartridges are located and how to replace them.
Oct 12, 2014 | HP Photosmart C6180 All-In-One InkJet...
Why does yellow not print on oki c5200?
The fountain under the yellow cartridge could be dried and clogged (assuming the cartridge is not dried up from too infrequent use and is not empty. If you stuff all around the fountain with rags and then gently force water into the fountain using a syringe you might be able to clear the ink passageway and restore yellow in the machine. Servicing the other fountains might be in order, too, since one clog is likely to be followed by others. Remember to use the printer more often to prevent such cloggingg. Also, you could try the built-in printer head clean function before trying the manual cleaning; but, generally, when it gets to the point of zero ink delivery, it's already to late to clear the ink clog with fresh ink, which is what the self clean feature does to try to dissolve the clog and restore ink flow to the fountain.
Aug 19, 2014 | OKI C5200n Laser Printer
Why does the blue colour turn out red on printing plus the yellow is mainly pink?? I am trying to print out invites for my son's 10th birthday & he is not impressed with the pink!!
See if the ink cartridges are installed correctly. It may be that your Magenta and Yellow ink cartridges need to change places. So, try replacing the cartridges, put the Magenta where the Yellow is, and the Yellow where the Magenta is.
Usually the ink cartridge placement follows this order:
Cyan, Magenta, Yelow, Black, so see if the cartridges on your printer match. Also, check to see if there are color markings on the print-head itself, and make sure the markings match the cartridge inks.
If the ink cartridges are aligned properly and the Black is printing out just fine, you may be looking at a software issue, and you'll need to remove the printer from the Devices list (go to Start -> Control Panel -> System), unplug the printer from the PC and restart. Then, install the drivers first, and after that plug in the printer cable to the PC.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 28, 2011 | HP Office Equipment & Supplies
WHILE TEST PRINT CYAN INK NOT SHOWING WHAT SHOULD I DO SIR
This issue will only occur if an ink cartridge(s) is or was installed inthe wrong position (slot) in the machine. When a cartridge is installed, the ink tube system is filled with the ink from the cartridges, to prepare the machine for printing. If the cartridge is inthe wrong position the tube will fill with the wrong color.
NOTE: If you just installed or replaced the ink cartridges and your printed documents are missing colors please refer to the solution - I just installed or replaced my ink cartridge and my printed documents aremissing colors. What can I do? Blank
To resolve this issue you will need to clean the print head.
NOTE: It may require 10 to 15 cleanings to clean the ink tubes and print head. During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to completethe cleaning process.
1. First verify the position of the ink cartridges:
a. Open the ink cartridge cover and check to make sure the ink cartridges are in the correct order.
b. Starting from the left side, the correct order is Black, Yellow, Cyan(blue), and Magenta (red).
- If the ink cartridges are installed in the correct order, close the ink cartridge cover and continue to STEP 2.
- If the ink cartridges are not in the correct order, remove the ink cartridges that are installed in the wrong position by pressing down on the release lever(s), located above the ink cartridge and remove the cartridge(s) from the machine.
Next, reinstall the ink cartridge(s) in the correct position in the machine by gently pushing the cartridge in until it clicks.
When all the cartridges are installed, close the ink cartridge cover.
2. After closing the ink cartridge cover, the LCD will prompt - Did youchange XXXX (XXXX = the color) This message will be displayed for ink cartridge that was removed. Press the - (Minus Key for No). This willkeep accurate data of how much ink is left in the cartridge.
1. Press the INK key.
2. Press OK to select Test Print.
3. Press OK to select Print Quality.
4. Press the COLOR START key.
5. Review the Check Sheet. The colors on the Check Sheet should be in a specific order: Black, yellow, Cyan (Blue) and Magenta (red).
a If the colors on the Check Sheet are in the correct order and are notmissing any dashes, press + (Plus Key for Yes) on the key pad and continue to STEP 7.
b If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - (Minus Key for No) on the key panel and continueto STEP 6.
6. The machine will need to perform cleanings to flush out the incorrectcolor or dried ink from the ink tubes and print head.
a. The LCD will ask you BLACK OK. If black is fully printed and is the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
b. The LCD will ask you COLOR OK. If any of the 3 colors (yellow, cyan (blue), and magenta (red) are fully printed and are the correct color, press + (Plus Key for Yes). If it#s blank, missing dashes or is the incorrect color, press - (Minus Key for No).
c. The LCD will say START CLEANING + for YES and - for NO. Press + for YES to start cleaning. The machine will go through a cleaning cycle that will take approximately one to two minutes.
d. After the cleaning is completed, the LCD will say PRESS START. Pressthe BLACK START key. This will print out the print quality check sheet again for you to check and see if your print quality issue has been resolved or not
NOTE: If you wait 1 minute after the cleaning cycle is completed, the display will return to date and time. You will need to go back to STEP 3 to print the Print Quality Check Sheet again.
e. If the ink color order is correct and all of the dashes are present, press + on the key pad to select YES and continue to STEP 7.
If the colors on the Check Sheet are not in the correct order, are missing dashes or blank or a color other than Black, Yellow, Cyan or Magenta printed press - key to select NO. Repeat the cleaning process byfollowing STEPS 6a through 6d. You may have to perform this procedure up to 15 times in order to clean the ink tubes and print head
NOTE: During the cleaning process, the ink in the cartridge(s) will be consumed. Additional ink cartridges may be required to complete the cleaning process.
7. Test by printing the document that had the reported problem (wrong color printing).
Dec 08, 2010 | Brother DCP 165C Compact Color Inkjet...
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
Blue ink - printing problem
Your Cyan cartridge is empty and need replacement. Maybe you can clean head of Cyan cartridge with alcohol but symptoms are the empty cartridge!
Good luck.
Sep 11, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printing
Most of the time, CMYK printers only work in conjunction of one another. If one cartridge is missing, it will require all of the missing or empty cartridges be replaced.
So, you'll need to purchase some more ink.
-Ernest
Apr 28, 2008 | Computers & Internet
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printer Problem
You are correct. You must replace ANY cartridge that the machine reports as empty to be able to print.
Mar 10, 2007 | Epson Stylus CX4600 All-In-One InkJet...
OKI C5400dn Led Printer Logo
71 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Argospete
Argospete
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
