Question about Electrolux Vacuums
Our Electrolux Ultra Silencer Harmony Z3347 just broke down. We need a new Non-Washable O2 HEPA H12 Filter serial no 117939-03. Do you know where we can get a new filter? Thanks
3 Suggested Answers
  • 109 Answers
SOURCE: I bought an Electrolux Accelerator vacuum cleaner
check the suction port it is probably stopped up or take the filter out and crank it up see what happens
Posted on Aug 23, 2009
  • 389 Answers
SOURCE: Hi, where can I buy a new H12 HEPA Filter for a
Not too sure, as am in UK myself! Suggest you look at www.godfreys.com.au which looks pretty promising to me. Good luck!
Posted on Feb 17, 2010
Bisell 9500 replaced hepa filter vacuum not turning on
Some (not all) of them have a wire or switch that the filter must press back between the filter and the back of the vacuum. It prevents the vacuum from running unless the filter is installed correctly (they never tell customers about this)
Apr 08, 2017 | Bissell Vacuums
An Electrolux Z8266 won't stay on. It'll turns itself off in 2" after it's been switched on. Could you help? Thx! Gary.
Electrolux Twin Clean Washable Hepa Filter EF78 900196701 8
Check for clogs first Motor restricted air flow will cut it off, also change your filters if you havent done it your vacuum is quite old
Apr 01, 2017 | Electrolux Vacuums
Can not get filters
While you are looking for a new filter, you could do this(as written in the instruction manual):
1. Hold the HEPA filter
by the edges and vigorously
"TapClean" the HEPA Filter
dirty side down on a hard,
flat surface until no more
dust is observed falling out
from between the pleats of
the filter.
2.
We recommend washing the HEPA filter
once a month or when suction
appears to be reduced. Let the HEPA
filter air dry completely for 24 hours.
3. Rinse the non-woven pre-filter and let
it air dry completely for 24 hours.
4. Insert the non-woven pre-filter.
5. Reinstall the HEPA filter in the
vacuum.
Have a good day.
GB
Nov 06, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
Jul 14, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hepa filter
you generally dont clean hepa filters .. you replace them .. temporarily you can tap them on the driveway to loosen up the big particles .. but the filter normally is replaced ... there are some filters that are washable in hot soapy water .. but hepa filters are normally not ..
Jun 06, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Feb 16, 2010 | Vacuums
Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Feb 24, 2009 | Panasonic Vacuums
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Vacuums Logo
98 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
