Question about Jenn-Air JGS8850AD Gas Kitchen Range
Control panel problems
Folks, Seems this model has continual control panel problems. I bought our jgs8850ad range in 1999. The control panel, although lit with a normal display, cannot be reset. I cannot start the oven, nor reset the clock. I cut off the power from the electrical panel, switched it back on. The control panel hasn't changed. I looked for reset buttons without tearing it apart and found none, although I found a pencil and an M&M underneath it. After reading a few horror stories, I'm now wondering about bothering to repair it at all. Sounds like the repairs run about $500 including handshake and parts for a $1,400 range. Comments? Bunk
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
SOURCE: Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Posted on Jan 06, 2009
  • 10865 Answers
SOURCE: No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Posted on Jul 17, 2009
  • 254 Answers
SOURCE: Our jenn air model js9860aab control panel buttons
no.. u must replace the touch pad assrmbly that whole unit.... i think u have a jds9860aab i believe... the part number u would need would be 74005750 it is for sale through sears at $272.00... u might need service.. u can take a look at part at repairclinic.com just type that part number in. ohhh also i believe this is a backordered part so most companies would prob take 2-3 weeks to get soo hope this helps..
Posted on Jan 28, 2010
SOURCE: I have a Jenn Air 'slide-in' electric
The unit has a bad touch pad
Posted on Mar 05, 2010
Familiar F3-1 error on Jennair #JGS8850ADS. Changed Control Panel, igniter, Sensor, thought problem was solved. After 1 week F3-1 error came back after oven is on for about 20 minutes and shuts the...
F3
or
F4
Shorted or open oven temperature sensor
(RTD) Check sensor harness and harness connection
between oven sensor and oven control. Replace oven temperature sensor (RTD) if
wiring is ok.
Dec 30, 2010 | Jenn-Air JGS8750 Gas Kitchen Range
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
F1-8
Problem fixed!!! Lowes is giving us a new stove!!!
Oct 08, 2009 | Jenn-Air JGS8850ADS Gas Kitchen Range
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the...
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Jun 27, 2009 | Kenmore 96012 / 96014 / 96019 Electric...
Bake element in oven not working
Unplug the range. Open the control panel and unplug the ribbon connector to the control. Plug the range back in. If the beep continues replace the control. If it does not continue replace the touchpad.
Mar 29, 2009 | Maytag MER5530 Electric Kitchen Range
I have a Jenn-air model # JGS8850ADS. An F3 - 1 came up. The temperature sensor was changed and it happened again on the same day that it was changed
hi there,
this is an overtemperature error that happens during self-clean. i would recommend ohming out the sensor and the harness and if they check out okay, replace the oven control itself.
Nov 07, 2008 | Jenn-Air Kitchen Ranges
DISPLAY ERROR F1-8
F1-8 commonly means shorted membrane. Unplug or shut off the circuit breakers for 15 minutes, plug back in/turn back on, if problem persists replace membrane, if they are integrated parts replace control board (some come with membrane on parts vary)
Always shut off power before any repair attempts electrically
May 01, 2008 | Jenn-Air JGS8850ADS Gas Kitchen Range
CONTROL PANEL REMOVAL
noavatar_s.png Navycpowif
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 1 votes
This is NavyCPOwif- As you read above I have a crazy Maytag H20 as well!
I am a research person so looked around a little last night and found a site. for DIY folks. Every one is halving the same problem. I suggest a civil action suit !!! But in the mean time I am going to have my Navy Avionics Technition husband tackle it rather then deal with Maytag right now. " cost almost as much as a military fighter jet, so he should be able to do it!" BUt I wanted to pass this information along to other DIY folks out there. We have not done it yet since ours just went crazy Friday night. So we disconected the door /water connection. But everything else seems to be working fine at this point. Serious about the class action suite!!! these should be recalled we bought ours in GA June 2006 so it seems that the ones made in the 2006 time frame are the ones with the issues- I assuem that the folks that are having problems with in the 7 8 month time frame have the same lot due to ours is 18 months old but we paid $2600 were some have paid $1500.00. So not sure but something needs to be done becouse the list of other issues with this fridge seems pretty long and very expensive.... Good luck!
Site to fix panel issue: for $3 to $20- DIY:
I have just fix my maytag M#MFI2568AEB at a cost of $3.00 Believe or not. You need to go to website hhttp://68.195.103.87:8083/liny/maytagice2o.htm Everything you need is on the site. (yes gets Maytag off the hook, but gets your fridge going quicker)
DIY site for those interested:
http://forums.partselect.com/refrigerator-freezer-repair/maytag-ice2o-digital-board-going-crazy-3189.html
Comment by Navycpowif, posted on Jan 17, 2008 We fixed our ourself with the information I posted above- cost was $5. no problems.... no new panel just 2 circuits.
Jan 24, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Jenn-Air JGS8850AD Gas Kitchen Range Logo
48 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
