Question about Acer Aspire 1414 Notebook
Files have removed not deleted to a unknown location
Upon add/removing programs from the C drive Many files located under ( programs not related to lost files.), a portion of files were either deleted or misplaced.
All file were in same Folder on C drive ad this consisted of Microsoft Picture It , diagrams, Microsoft Word documents and Easyshare JPEG and PNG files.
All files were previosly saved in indivual folders and placed into one major folder. Retained for approx 18 months .
After removing a exsiting outdated program (This program was not used or common)
I then found upon opening this other folder on C drive that many sub folders still present did not contain indivual files, all files previously saved were no longer present. The folders are still present however after doing a search via file name, all these files are listed " as moved and unable to locate "
Note: The major folder was not deleted or moved however all files within these folders were moved or somthing and I still cannot locate or recover them.
All programs these files are under are , Microsoft Picture It , Microsoft Word documents and Easyshare . which these programs have not been effected.
  • 258 Answers
There is no reason why this should happen when removing a program or software.
Have you tried a system restore?
It doesn't normally retrieve missing files but as it is files specifically related to a program it may work.
Backup everything you want first, e.g copy my documents etc to an external drive
Start --> All programs --> Accessories --> System Tools --> System Restore
Click Restore my computer to an earlier date
Select a date in bold before the date when you removed the software
Click Next , next
Leave the pc to restore, power plugged in
You can always undo this restore later
If problems, please post results and I will help
Error messages etc.
Thanks
Posted on Jan 17, 2009
Instructions delete
This describes what Deal4me is:
Deal4me adware how to remove it
First, you can uninstall it through Start > Control Panel > Add/Remove Programs (Renamed Programs and Features in Windows 7)
You will also want to download, install, and run an Anti-Malware utility, such as the free version of Malwarebytes from:
Malwarebytes Anti Malware Pro
Aug 31, 2014 | Computers & Internet
How to remove snapdo
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here. and you might have other web search toolbars interfering
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help Click on the tools at the bottom of the drop down list will be internet options or Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser below that will be change search defaults click on settings you will see all search Providers Toolbar extensions and Accelerators you have have if don't need any of them you can disable or remove them
also b> http://download.cnet.com/jetclean/3000-18512_4-75627788.html JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again. Then delete cookies Here is a very simple guide on how to delete cookies manually from your computer.
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted.
Feb 18, 2013 | Toshiba Satellite Computers & Internet
Samsung laptop left touchpad button
Feb 18, 2013 | Samsung RV520 Laptop
Removing certified toolbar webpage
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. b>
Feb 10, 2013 | Microsoft Internet Explorer 9
Uninstall vgrabber toolbar
Feb 01, 2013 | Computers & Internet
Remove searchnu.com/406
Jan 31, 2013 | Microsoft Windows XP Professional
Remove snap do
Jan 30, 2013 | HP Computers & Internet
I had google chrome, then i uninstalled it. now i want reinstall and i get message:assembly is not installed on your system (Exception ffrom HIRESULT:0x800736B3)
Click on "tools" in your browser. This is usually located in the upper right corner of your browser. Click on Internet options. This will appear in the drop down box and is usually at the bottom. Under the "General" tab look for "Browsing History." Under this heading you can click "Delete" to have the computer delete all cookies for you automatically however to delete the cookies manually click on the "Settings" tab Click on the "View Files" tab under the "Temporary Internet Files and History Settings" box that pops up. When you do a second box will pop up with a list of cookie containing files. This may take a few seconds to load so be patient while waiting for the cookie files to load. Highlight any cookie file that you would like to delete. You can highlight more than one at a time by holding down the 'Ctrl" button on your keypad Delete the files that are highlighted by clicking on the "delete this item" located to the left in the same box. As soon as you do you will see the selected files disappear. When you are done just "X" off; this completes your task of manually deleting cookies. You might also do a disk clean up click start click on computer to open right click on your hard drive usually C: select properties in the general tab select disk clean up click ok you can view files to be deleted. b> Hope this helps.
Jul 29, 2012 | Microsoft Computers & Internet
If I delete something from my computer, is it also deleted from the Seagate?
If you delete a shortcut icon from your desktop, you are only deleting the shortcut, not the program which is stored on your Freeagent (or other hard drive that you may have). If you use add/remove progams to remove programs, or windows explorer to delete files from your computer they will be permanently removed from whatever hard drive they are stored on.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Jun 24, 2011 | Seagate Freeagent Goflex Desk 3 TB Desktop...
I can not download or remove or add any new programs or msn
There is another way of getting rid of programs in your computer other than going to your Control Panel's Add/Remove Programs menu. Try to locate the where the program is installed. If your computer has more than 1 partition (e.g. Local Drive C, Local Drive D, and so on), see which partition has that program. Use Search function from your Start menu (located on the lower left of your screen), click on All Files & Folders then 2 rectangular white boxes will appear. On the 1st box you type the name of the program you are looking for then click on Search button below. Once the results are displayed, right click on the listed program (it should exactly be the program you wish to remove, okay?) & choose Open containg folder. Once there, you can now manually delete each file & delete the folder itself. If there are files that Windows won't let you delete, try renaming them by changing their filename extension. This is especially true with files having a .dll at the end (those are driver files, they say). Change .dll into .txt then hit Enter key. If still you can't delete them after changing the filename extension, you may have to restart your computer & go back to those files to see if you can delete them already (they should NOW be deletable). Once all files & the folder containg it are gone, go to your Control Panel's Add/Remove menu. Click on the program you were trying to remove to highlight it then click Remove button. It should display a dialog box saying, "This program or the folder containing this program have been removed. Do you wish to remove it from this list?" Select YES.
I hope this will solve your problem. Let me know if it worked on your computer, okay?
Dec 05, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Acer Aspire 1414 Notebook Logo
164 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
