Question about Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television
It will not turn on.
The green light contiunes to flash. I have pushed in on the reset button and unplugged the unit. No change. It continues to flash and doesn't respond to the remote or the power button on the tv itself.
I have the same problem with the ws-65613 ,what do i tell the repairmen or how do i fix it my self.
Posted on Dec 13, 2008
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    Green "ice size" light is
    try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
    Mar 06, 2011 | Refrigerators
    I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
    I found this on another website, most likely it is your power supply capacitors.
    1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
    2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
    3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
    4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
    5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
    6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
    Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
    1. DM Module Capacitors have FAILED.
    2. DM Module is defective.
    3. EEPROM Board failure
    4. Power Supply failure.
    Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
    Mitsubishi TV won't turn on green light flashing
    Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
    Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
    Charging Black and Decker Simple Start
    First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
    Jan 19, 2009 | Black & Decker Simple Start Car to Car...
    Continuous flashing green "timer" light on front, tv won't reset
    Is your set a mitsubishi/ If so you need a DM repair kit they have various kits for the different mitsubishis at the following link under the repair kit category. The kits contain the replacement capacitors and instructions on CD.
    http://servicemanuals.vstore.ca/
    Jan 15, 2009 | Televison & Video
    Green power light will not stop flashing and tv will not turn on or off
    You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
    May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
    Timer light
    does the light blink for more than 70 secounds? if it does go off after 70 seounds the keyboard lockout feature may be engages to unlock press and hold menu on keyboard for 10 secounds. If the set contiunes to blink after 70 secound after plug in then you maye have power issues or a possible bad digital board
    Nov 04, 2007 | Mitsubishi WS-55813 55" Rear Projection...
    Flashing Green Light on Front of 73" Projection TV
    on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
    Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
    Mitsubishi WS-55313 55" Rear Projection HDTV-Ready Television Logo
    120 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
