Question about Compaq Presario 700 470024-192 Notebook
Compaq Presario V6000 Power Problem
Computer was working fine and then suddenly just died. now it won't run and won't power up the blue LED on the side won't even light up and it died while plugged in so it just isn't a dead battery
  • 39 Answers
Sounds like the power supply might have died, probably before the battery did. Once the battery had run down, the computer simply died. Easiest way to check this would be to take it to a computer shop - they shouldn't charge you very much just to check the power supply - or try to locate another supply just like it and see if the computer will boot from the new power supply.
Graye
Posted on Nov 09, 2008
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
I have a compaq presario v6211au with amd turion processor i hv purchase it in 2007 , after purchasing it gave me many problems like battry, adapter, but one problem still coming about its oipening...
the screens is dead right, no BIOS screens at all, means.? what?
power problems
main battery out , run now
coin cell dead? 2.9v and above is good.
power pack bad, 19vdc ok , is it.
power jack at the MOBO edge bad, as all do.?
see this?
https://www.amazon.com/Presario-V6210us-V6211AU-V6211TU-Compatible/dp/B009WWBWFY
Jul 17, 2017 | HP Compaq Presario V6000 Motherboard -...
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
May 03, 2010 | Compaq Presario 5000 PC Desktop
My power supply for my Presario V6000 died due to broken wires. The battery powered the computer until it died. Now, the new adapter will not power the computer.
This is a common eevnt the battery get so flat that the adapter will not charge it quickly.. You need to leave it totally alone for at least 8 - 12 hours... To see if the adapter actually works and PC is good, take OUT the battery, and plug IN the PSU, the PC will work, sans battery just on PSU. If OK, then charge up as related. It will do it after a ling time.. Sometimes batteries go so flat they are ruined, sa a new one may have to be gotten IF it does NOT charge up.
Mar 11, 2010 | HP Compaq Presario V6000T PC Notebook
My Compaq Presario f500 series Wont turn on anymore
I would like to help but it sounds like it's over heated and needs a repair guy to look at it
Jan 11, 2010 | Compaq Presario Notebook
My v6000 presario will not turn on when power cord in the blue light on input just flashes nothing switches on at all
Unplug the power cable and pull out the battery.Wait 10 min and put the battery back again.If this not help your computer need service.
Oct 26, 2009 | HP Compaq Presario V6000T Notebook
No power
eh, did ya charge em?
May 12, 2009 | Compaq Presario Notebook
COMPAQ Presario v6000 Died during Tstorm
My 6000 also died in a thunder storm with power surges.  Power seems to be coming in to the cord, but the ON/OFF button on the front does not turn the computer on.  Totally black screen, with no response.  Hoping for help too.
Feb 27, 2009 | Compaq Presario S6300NX PC Desktop
HP Compaq plugged in & blue light on but icon says NOT plugged in
Check power out put of the adapter is it giving you the correct readings
Try to remove the battery and run it from adapter itself check to see if its working
Reset the battery ..by removing it from the system
Nov 10, 2008 | Compaq Presario Notebook
Compaq presario v6000 s/n: cnf6412pn1
Compaq Presario V6000 AUDIO SOUND DRIVERS HOW TO GET
Mar 15, 2008 | HP Compaq Presario V6000T Notebook
Compaq Presario 700 470024-192 Notebook Logo
165 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
