Question about Zenith C27A24T 27" TV
Zenith 25in. System 3 TV. Intermittent problem with color going all red??
Hi; This Zenith Tv is like 20years old and has been a awesome tv.Run's fine for hours,all of a sudden goes all red,for a few min.then ok again.Then may go for hours and it will start again,all red color,no other problems at all.Any Idea's?? Has been ok for 2 day's now,what could be causing this?
  • Dave Segala Apr 15, 2007
    Must have been a connection problem,took apart moved stuff around,and it hasen't acted up since Nov. of 2006....Thanyou for all the help,It's sure ly not the picture tube.Come's in great,color and brightness,still haven't found the bad connection but,Like they say,if it isn't broke don't fix it.Thankyou
This is a common problem bad picture tube juck it
Posted on Apr 14, 2007
    President:
  • 3,130 Answers
It certainly sounds like a drive problem in the set. It could be a bad connection on the CRT socket, a componet on the CRT driver board, a bad drive transistor, a connection between the CRT driver board and the RGB /video jungle IC, or the RGB/video jungle IC itself. If you know how to solder and or have some sort of solid state repair experience, you should be able to find this problem by simply probing around with a wooden or plastic tool tilll the problem arises. If you have no experience, there is no easy quick fix. You should find a local repair person to assist you with this repair. good luck PS Please dont forget to rate this thread.
Posted on Oct 24, 2006
SOURCE:
Have sanyo 25in color tv with no manual and want to hook up a wiisystem it is currently hooked up to dishtv model ds25320 and family group vc8b
Connect the yellow rca plug from the wii to yellow jack on the tv marked AV1 and the red and white rca jacks from the wii to red and white rca jacks of the AV1 hookup. Simple.
Aug 30, 2011 | Sanyo Televison & Video
Hi. I have a Zenith 42" plasma TV - Z42PQ20 that's
I had this exact problem on my TV, everything said it was the power board. It wasnt, luckily i was able to return that board. It was the YSUS board.
I should have done this this first but this is how i verified the old power board was good. Unplug TV, take the cover off and disconnect the wire harness going to the YSUS, plug TV in and turn on. If led stay blue its the YSUS.
Mar 19, 2011 | Zenith Televison & Video
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
No color plugs for tv
Go to Wal-Mart or Radio Shack to get IF converter hookup for DVD you can plug TV& dvd Jacks into this.
Dec 26, 2008 | Zenith B25A74R 25" TV
Color Problem
prob bad crt. blue gun weak. new tv is answer.
Nov 17, 2008 | Zenith B25A74R 25" TV
Tube set zenith tv
This is very typical of a Zenith set.Your picture tube will have to be replaced.One of your 3 primary colors (red,green,&blue) have turned off leaving you with the color of the dominant color.I would heave it.
Feb 10, 2008 | Televison & Video
Red color gone on tv?
is the red gone on all inputs? do you have the tv hooked up, to a sat box, cable box via component video (Red, blue, green connections)? if so check the red cable on both ends.
Jan 29, 2008 | Zenith D52WLCD 52" Rear Projection...
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
An old zenith tv
press -------- |tvvcr | |source| -------- its by the timer button on the bottom of the remote
Aug 11, 2007 | Zenith C27A24T 27" TV
50" rear projection zenith television
does it look like this:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 31, 2007 | Zenith IQC50H95W 50" Rear Projection...
Zenith C27A24T 27" TV Logo
150 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
