Whirlpool Duet-Error code F 02/wont spin and drain
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about half of the time. The washer was purchased in March of '04. Can you help??
Fred
  • 1 more comment
  • BobOso42 Nov 09, 2008
    Hi! Thx for the tip! This was so helpful. My only issue was that my model didn't give me the diagnostics mode as directions explained. I was able to run a rinse/drain cycle for the fill-time, then switch to the spin/drain cycle to make sure all was working. Thx. You're a life saver. Fred
  • Anonymous Mar 31, 2009
  • Anonymous Apr 15, 2009
    Thanks a lot! ... figured it had something to do w/the draining... wife had washed some rugs months back, bet it's the backing from them
  • 5,911 Answers
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 09, 2008
You should clean the the drain filter and the drain hose first but if the pump is removing water and the F02 is still hanging in there try this, it worked for me. Remove the back of the washer and in the upper left is a pressure switch that tells the computer the where the water level is. Remove the black rubber tube from the switch and blow into it. Mine had a small obstruction and didn't let the switch see the pressure change (water level change). I did replace the pump and didn't need to.
Posted on Sep 22, 2009
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
At the end of the normal wash cycle my washer begins to beep repetitively and shows an error code of F 02?. It will not spin and drain. We've began to switch it to Drain/Spin cycle and this works about...
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 30, 2011 | Washing Machines
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
display.
or kinked.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I get the error code S02 on my Duet washer. It
02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY WHIRLPOOL DUET FRONTLOAD WASHER BEEPS AND CUTS OFF 2 MINUTES BEFORE CYCLE ENDS DISPLAYING F 02 CODE?
The F 02 error code is a long drain problem. It could be that there is something clogging the drain line or a kink in the line, the drain pump trap is clogged, something lodged in the drain pump or the drain pump not working properly.
Here is some info I found on this site to help me clean out the drain pump trap and to replace the drain pump if cleaning it out doesn't work for you.
Aug 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
displayed.
Possible Causes / Procedure
or kinked.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
10,157 people viewed this question
Top Washing Machines Experts
