Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Unit keeps stopping when hot weather
I have a Mr.Slim in my shop in Hong Kong and whenever the outside temperature exceeds 30Deg C the unit keeps stopping and turning off automatically. I cannot restart the unit until it cools dowm later in the afternoon. I have had the unit cleaned and serviced but it continuously keeps stopping. The servicemen have no idea to why this is happening. Hope you can help so that we can pass on the fix to the next serviceman we get in. Thank you Kind Regards Dean
  • tbrown73 Jun 18, 2008
    We have the same problem which has continued after being recharged with freon. No error codes on thermostat, just a flashing "filter" on the screen.
Hi, it's summer again and hot. Finally got someone with some brains to come and look at the airconditioner. I showed them your reply to what the problem may be and like magic, they re-gased the aircon and now it works perfectly. Thanks again Kind Regards Dean
Posted on Jun 27, 2007
    Novelist:
  • 75 Answers
Hi, I am not familiar with your particular unit but it sounds like the compressor is getting too hot which could be caused by being low on freon. The large refrigerant line should be cold and sweat all the way up to the compressor after it has been running for a while. If it does, the freon is ok. It could also be a dirty condenser coil, bad bearings in outside fan motor or bad capacitor on fan motor or compressor. Check for wires that are burned or have been getting too hot. There are other things with heat pumps that could cause it but they are unlikely to happen. You might also want to make sure the voltage and hz is right. The only thing I could find information on was the 110/220 60hz (60C) You may only have 50hz power there. Good Luck. Let me know if I have helped. kstfas
Posted on Oct 25, 2006
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Hello im using Mitsubishi AC...everything was ok.We went on holiday,we switch off the fuses...after 30days ac not working ...light flashing 7 times...no hot air,just cold...we are freezing...whats wrong
Normally, any a/c keeps off for long time in winter, there are chances to get gas become ice in compressor due to ambient temp. It/s advised to service the unit with warm water and then start the unit. Better call repairman to check amps whenever you restart the unit after long period.
Dec 30, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Just installed 5 units in my home. all four work
It sounds like the condensate from the drain pan is not draining correctly! The drain tube from your Air Handler unit may be kinked or not properly installed. The condensate water from the unit should be drained outside at least.
Jul 19, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
My Mitsubhishi Mr. Slim MSZ-A17NA 1 is drippping water on the inside. I have turned it off for now. What should I do? We're in Mississippi and it is a hot day! thanks
Hi!!
Make sure the unit is leveled, there is a drain hose coming from rigt side of the unit goes through the wall to the outside and down, this hose is probably clogged up.
Go outside the house and look for it. there should be some tubing wrapped in insulation going up to the roof top and a drain hose coming down. You can try to unplugged it from the inside using a wire clothes hanger or you can blow air from the outside end into the unit, you only need a small blow and you can use a flexible funnel or a piece of garden hose and some tape to do it. if you are going to do this make sure to drain all water from unit using a towel to avoit splashing. This works all the time.
Don"t forget to rate this post. Good Luck!
Jul 01, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
No heat generated from the inside unit in Misubishi Mr. Slim
If you do not have a windbaffle installed on the outside unit the unit may never come out of defrost in low ambient temperatures. Depending on the outside temperature it might be telling the pcb to stay in defrost to keep the compressor from slugging and being damaged.
Jan 20, 2010 | Heating & Cooling
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Hot air coming out of ac
The workings of split units can be difficult to repair. I would have a professional repairman look at it.
May 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Display E4 code then only normal air blow in the room
check your cap also you may have a bad condensor fan
Feb 21, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr slim 12,000 btu 110 volt
Sounds to me like yo have dirty condenser coils (outside unit) After this runs and gets hot it loads the compressor because it can not release heat out of the condenser coil it also may have a restriction somewhere on the high side that could cause this maybe in a txv or in a line filter.
Hope this helps Ya
please rate me
Jul 20, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
465 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
