Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
Playstation 2 paddle
My dog chewed my paddle, and the wires are showin and i was wonderin if anyone can help me try to rewire my paddle for my ps2.....plzz and ty...
  • Anonymous Mar 14, 2009
    I have a ps2 controller but it just doesnt work for somereason. I dont know why.
  • JamieIsHere May 11, 2010
    depends how badly if there all like shredded buy a new remote other than that with out better explanation cant help ya
I need a wiring schematic for a craftsman riding lawn mower 917287011
unfortunately they started putting basic info in english and spanish instead of giving wiring and parts breakdown in the owners manual.
try this on page 33 and 34 is wiring, hopefully its similar to yours.http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0312062.pdf
parts breakdown is at http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Craftsman-Parts/Model-917287011/0247/1509200?pathTaken=modelSearch&prst=0&shdMod=917287011
Jun 24, 2014 | Craftsman Garden
I have a zanussi DA 4552, a rat has chewed through most of the machines wiring, i need a wiring diagram so i can try to rewire this machine, please can anyone help me with this
No idea to be honest but you must be able to find the colour of the wires at the ends and then re-connect them i would have thought unless its all the same colour wires ,or look at the council scrap yards and see if you see a similar machine and take the wireing out of it but take plenty of pics on the phone so you know where they all go ?.
Jan 21, 2012 | Cars & Trucks
Well my dog chewed my wii power cord so what im wonderin is would it still work if i wired it back together... just temporarily until i go to the store this week. i understand that if it does work its my...
I would HIGHLY recommend AGAINST attempting to repair the power cord or use the unit with the damaged power cord there is too high of a chance of getting shocked or worse causing a fire. Step away from the console take a break and go get a new power cord =)
Apr 10, 2011 | Video Game Consoles & Games
The dog chewed the wiring to the condesor outside. i re wired and now the furnace turns on but not the a/c unit ouside?
Hi, well you have 1/2 of it right. Recheck the wiring and wire it color to color as you are not getting 24 volts to the condenser. If you have a gas furnace and not a heat pump you will only need 2- wires to run the outdoor unit, red and yellow. Make sure the dog didn't chew through another section also.
Shastalaker7
Jun 29, 2010 | Goodman CKL24AR24 Air Conditioner
My grandsons dog chewed thru the wires leading to the TV. I need the wiring diagram to reconnect the wires. I also need to know how this item is activated utilizing a tv,s vcr connections, yellow video,...
Yes, your colors are correct. To rewire the two ends together, use a method similar to THIS, (it is about audio, but the same theory applies to all three cords)
If the cords are completely severed and you do not know which wire went to which color, you can rewire them to any color you wish. You may just have to plug/unplug them to the tv with trial and error until you figure out which one belongs where.
Dec 04, 2009 | Video Game Consoles & Games
My dog chewed up the wire that go's into the socket and now we rewired it and the cd player doesnt work anymore how do i resove that problem?
sony makes the cheapest cool lookin **** expect this in the future my friend replace tis a shame i know
Oct 31, 2009 | Sharp CD-DD4500 System
Dog chewed cord on bissell model 6579-2 how do I replace it?
You can cut the bad section of wire out of the cord, cut the insulation on the cord to get to the wires. Match your colors, strip the insulation from the individual wires and twist together. Wrap each wire with electrical tape (making sure no wire is exposed, can be a fire hazard), then wrap the cord with electrical tape. The cord will be a little shorter, but should work fine.
Jun 16, 2009 | Vacuums
1/2 HP Sears Liftmaster will not close
YOU PROBABLY HAVE A BROKEN WIRE ON THE SENDING EYE. THIS WOULD CAUSE IT NOT TO LIGHT AND THE RECIEVER NOT TO GET A SIGNAL MAKING IT NOT LIGHT.
YOUR DOG IS PROBABLY THE CULPRIT AGAIN . THEY TEND TO SNIFF AROUND OR JUST GENERALLY BUMP INTO THE WIRES (SOMETIMES THEY CHEW THEM).
IF NO OBVIOUS BROKEN WIRES OR LOOSE CONNECTIONS CAN BE FOUND. YOU CAN TEST THE WIRING BY USING DOOR BELL WIRE TO TEMPORARILY REPLACE IT - THE FAULT COULD BE INSIDE THE WALL OR UNDER A STAPLE WHERE THE WIRES GET SMASHED (THIS ONE WE CAN'T BLAME ON THE DOG) :)
IF YOU REWIRE COMPLETELY (PAY ATTENTION TO THE POLARITY OR THE TEST WILL NOT BE VALID) AND THE LEDS STILL ARE NOT ON YOU COULD HAVE A DEFECTIVE EYE
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nintendo ds lite charger
just buy a new one i use 3rd and 1st party work the same keep it away from your dog
Jan 15, 2009 | Nintendo DS Lite Console
For PS2 "The Dualshock 2 Analog Controller is not detected." What should be done to fix this? Mom with 3 kids home from school! Help!
This could be the PS2 console. You need to try a different Dual Shock controller to determine if the problem is the controller itself or the ports on the Playstation. The normal problem here is a dirty connector on the Playstation. Clean the connector or you may need to check the Fuses inside the Playstation. This requires specialized skillls.
I have seen where Dogs have chewed the cable running from a controller, and caused the problem.
Dec 30, 2008 | Sony PlayStation 2 (PS2) Console
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
377 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
