Question about Panasonic PV-GS250 Mini DV Digital Camcorder
Can't get my computer to recognize the device
When I hook up the provided Jabra brand usb cable, my computer says it does not recognize the device. When I go into the MotionDV studio it says there is no device hooked up to the computer. When I first plugged in the connection cord to the camera it did not plug in real easily and I am wondering if it is easy to damage the port or the cord. I have installed all the proper drivers. I GIVE UP.
Are ther any other devices I could buy that would read the digital tapes that would connect ot my computer easily so I can begin editing my movies?
  • 689 Answers
You may use different USB ports. Make sure your computer USB is v2.0 Computer's Bios and Chipset update could be a possible solution. You may also try Firewire/1394 Connection which is more reliable and faster for video editing and conversion.
Usually in professional use hook up the Camcorder directly to the computer is not very preferred, Using DV converters are more common such as Canopus products as you can find them on www.canopus.com
Posted on Nov 10, 2008
Coby mp3 player
Try to reset it if possible.
If the computer charges it then the computer recognizes it as a connected device. That's how usb works. It could be you need a new USB cable. Many devices that use USB for charging do not have the data leads connected in their cables. This is called a "vampire" connection as it only sucks 5 volts DC from the computer/charger .
Apr 03, 2014 | Coby MP-705 Digital Media Player
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead,...
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
Features
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here: http://www.sakar.com/p-1124.aspx?categoryid=182
Sep 09, 2010 | Sakar (M01517) 5-Port USB Hub
Camera wont sync with any computers
YOU HAVE TO INSTALL DRIVER BEFORE YOU HOOK THE USB CABLE.
Jul 23, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Feb 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
O2 xda 2 mini pocket pc usb connection problem
how i get my o2 xda ii mini drivers?
Aug 12, 2008 | O2 Xda II mini
Jabra vbt135z
How do I have to set up my Jabra head set?
Jan 15, 2008 | Jabra BT350 Bluetooth Headset Headset
Ilo is not reconized by the computer
I have the ilo and i had the same problem! I hooked it up with my husbands Creative brand mp3 cord and it worked. It recognized it as the ilo and allowed my to sync. I hope this was helpful.
Dec 27, 2007 | iLO (2 GB) MP3 Player
Computer Won't recognize MP3/MP4 Player
Go to device manager. Remove all USB ports. Re-boot. See if that workds.
Dec 20, 2007 | Samsung YP-T8 Digital Media Player
Computer fails to recognize smt5600
you can use any USB cable, there is nothing specific about any particular brand... now the computer has to recognize the phone. You need the software/driver.
Sep 11, 2005 | Audiovox SMT5600
Panasonic PV-GS250 Mini DV Digital Camcorder Logo
247 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
