Question about Toshiba Satellite M45-S165 Notebook
Toshiba m45-165 external usb keyboard wont work
I have tried to separate exteranal USB plug and play keyboard with my toshiba m45 laptop, and cant get xp to recognize the keyboard. I have tried both ports. downloaded the external drivers, tried reinstalling the usb drivers and keyboard driverse. updated xp, etc. seems like this may be an xp problem. any ideas where to go for help. so much for plug and play.
  • johnfp_707 Nov 24, 2008
    yes and yes to your question. apparently its a problem with microsoft os that they wont fix for keyboards on this particular toshiba laptop model. so i replaced the main keyboard, as i found one for 17 bucks. its a bit tricky to replace the keyboard but not time consuming. the usb ports are fine, i use them for my camera, etc. microsoft are a bunch of jerks. thanks for replying, have a good thanksgiving and Christmas.
  • Anand Srinivasan
    Anand Srinivasan May 11, 2010
    are you able to see the keyboard class of drivers in the device manager... are other plug and play devices working fine...
Toshiba satellite 2435-s255 keyboard & touch pad not working, reconnected keyboard cable. reinstalled drives. Still not working. what else to check?
Laptops are a bit trickier to work with. If the keyboard *and* touchpad aren't working, you may have to contact Toshiba for assistance, assuming the product is in warranty.
You may also want to see if an external (USB) keyboard and mouse work.
Aug 01, 2016 | Toshiba Satellite Computers & Internet
Toshiba backup software
Determine how much space you'll need to back up your Toshiba laptop's hard drive.
If you are intending to back up your entire hard drive, or have a lot of video and music files you want to save, you'll likely need an external hard drive.
On the other hand, if you only want to back up your most important documents, a USB drive should suffice.
Separate your video, music, pictures, games and documents into separate folders.
Right-click each folder and then click "Properties." Do this for your C: drive, too.
Locate the "Size" or "Capacity" section on the "General" tab.
The number to the right indicates how large the folder is, with all the files included.
This information should give you an idea of what kind of secondary storage system you'll require. If you're looking at over 100GB of storage space needed, you'll probably want an external hard drive.
Purchase an appropriate drive that includes backup utilities.
Some external drives and USB drives come with backup software.
Once you install and configure the software, all you have to do is press a button--either on the drive itself or on your computer's desktop or taskbar--to start the backup process.
Schedule your drive's utility software to back up your Toshiba laptop files once a month.
Your USB or external drive should be plugged into the laptop on the scheduled backup dates.
Store your most important files on an online storage facility, such as Mozy, DropBox or Toshiba Online Backup.
In case anything causes damage to both your laptop hard drive and your spare drive, you will still be able to access the files online.
http://download.cnet.com/macrium-reflect-free/3000-2242_4-10845728.html
Backing up your computer shouldn't be a tedious task. Macrium Reflect Free Edition makes file backup incredibly easy thanks to its intuitive user interface and helpful wizards.
bonus its free
hope this helps
Oct 03, 2012 | Toshiba PH3100U1EXB 10TB Desktop External ...
Keyboard not working
You should be able to use an external keyboard....just plug a usb keyboard in and boot up...this is probably your cheapest solution and will get you up and running again quickly :-)
Aug 27, 2012 | Toshiba Portege M100 Notebook
Nb305 error 0211
From the description you have a virus, go into safe mode when you start the computer, now you should be able to do a system restore and bring computer back in time before you had this trouble, if this works do a full scan using your antivirus to clear out any problems that may be lerking around.
Apr 08, 2012 | Toshiba mini NB305-N600 Netbook
I have toshiba Tecra 9000 laptop, its USB ports and Keyboard EXTERNAL port is not working. please help me
It's a common problem with the Tecra 9000's - either one or both USB ports and sometimes the external KB port along with it. The 2 USB's and external KB port (and the TV out port next to it) are all located on the same daughterboard that plugs into the motherboard, and in your case, more than likely the connector on the motherboard is bad (gotten loose). There's no easy fix for this unless you've got an ultra-fine soldering tip, good soldering skills....
How about a workaround? A PC card (PCMCIA card) that gives you 2 or 4 high speed USB 2.0 ports - it'll stick out a little on the right hand side, but in return you'll have fast USB ports, and you can use a USB keyboard with the thing.
Sep 14, 2011 | Toshiba Tecra 9100 Notebook
Hi there, I have a Toshiba external HDD 250GB that is giving me some problems and need some urgent help! When I plug my external HDD into my laptop everything seems to work fine. The lights come on, the...
It sounds as though your issue is one of in adequate power. Do both the external HDD have their own power source, or are they powered through USB? if they are powered through USB it may be that as soon as the second drive spins up to transfer the files, it overwhelms the limited power of the laptop. You can try it with the laptop plugged in (though this may not provide it with more power than the battery) or by purchasing a usb hub with its own external power source so that it is not drawing power from the laptop, or purchase an external hard drive with its own power source
The other option is simpler and free, and its to copy the files first to your laptops own HDD, then unplug the source external hard drive, and then plug in the drive you want to copy to, then transfer the files from your laptops hard drive. This will of course take twice as long, but will cost you nothing.
May 29, 2011 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Keyboard frozen, cannot unfreeze
First try pluggin in an external keyboard, if that works and your internal one still doesn't work after unplugging the external one, you may have a problem with the insides (small plugs and cables) other wise if the external one doesn't work, it could be many things, ie cmos, other cables, other plugs, entire USB system, power supply (internal), too much to list and troubleshoot here.
Jun 25, 2010 | Toshiba Satellite L505ES5018 Laptop
Computer wont boot. Keyboard wont work
Make sure all connections are free of debri....USB connections can become wallerd out so to speak and create the intermittant problem... Built in keyboard could have been loosened underneath the keyboard on notebook is a flexible connection that if pc has been droped or fallen so to speak could be needing to be reseated........
Oct 14, 2009 | Toshiba Tecra A5-S416 Notebook
Toshiba Satellite a105-S2716 keyboard doesn't work. Soda spilled on it. External USB keyboard does work. How do I fix it?
I think your Toshiba got grounded or short circuit inside. Better also to use USB Keyboard, it works.
Aug 18, 2009 | Toshiba Satellite A105-S2716 Notebook
Keyboard just quit working
Its most likely just a bad keyboard unless something got spilled on the laptop. I would call Toshiba customer support and have a toshiba repair shop look at it. 1-800-457-7777
Feb 07, 2009 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite M45-S165 Notebook Logo
439 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
