Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox XD 100
One band (vertical) which doesn't print - just comes out blank
    President:
  • 2,072 Answers
I would first try opening the right side cover and inspecting the corotron. There is a small opening where there is a very small wire. Check for a small piece of paper in there. It would block the transfer corotron voltage and cause that line.
Then remove the toner and drum. Look at the toner cartridge and see if you can determine if its out of ink in that area. Then look inthe machine with the drum and toner out. Locate the laser and see if it the glass **** is dirty in that ares or blocked.
By the way. if there is no paper in the transfer wire, take some alcohol and clean it with a q tip to remove contamination.
Posted on Nov 09, 2008
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
Tip
Xerox XD or XC Series Copier Drum Light Drum Unit Reset Procedure
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works on nearly all Xerox XD and XC Series copiers.
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
White vertical band in Cyan and Black
try to clean the laserwindows of the printer.
Mar 25, 2013 | Xerox Phaser 6125 Laser Printer
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I have a number 4 and a letter H flashing
Good Luck and Thank You for using Fixya
Jul 16, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
HEAD CLEANING DOES NOT FIX GAPS IN NOZZLE CHECK
Head cleaning is for fixing horizontal band. If some point of head cloged, print out will show horizoantal banding. For vertical banding, try using head alignment. Have yo tried printing without high speed (disable high speed option)
May 20, 2010 | Epson Stylus C84 InkJet Printer
Need printer driver for Windows Vista
It' also listed at Microsoft as incompatable with vista. Best you can do is get a cheap old used machine that runs XP and set it up as a print server for your network, (set it up with printer sharing) send all of your documents thru it for printing. Sorry it's probably not the answer you were looking for but it is the only solution I've found for mine. I bought an old P3 machine running XP for $5.00 at a garage sale and it's working great as a print server.
May 26, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
102 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
