Question about HP Pavilion dv4000 Notebook
Need help hello everyone need help my cd /dvd drive does not work most of the time i cant open it manually or by cliking in the eject when i finally get it open it will not read it will not spin it show like the drive is empty can u help me put the dvd/cd drive on my Compaq presario laptop does not always open and also turns off before a program has fully installed. It will also sometimes not read a disc at all.
Change cd rom v2010
Posted on Jan 09, 2012
    Problem Solver:
  • 4 Answers
Hi! All of you
thish the cd-rom drive LENCE problem
if you Need to you change completed drive..
ok
have great day
Posted on Nov 10, 2008
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
DX4300-150
CD/DVD Drive Tray problems
Mar 12, 2013 | Computers & Internet
Dell cd drive door won't open
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
My MSI GT660 Dvd will not open or eject
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
Feb 18, 2013 | MSI GT660 Series CD 8X DVD RW DL Burner...
My cd/ dvd drive will not open dvd disk.
Hello lrobinson65,
Here are 2 possible silutions:
1). Use a paper clip or pin to press in the small hole on the cd tray
OR
2). Click the start menu (lower left-hand corner). Then click on 'Computer'. Finally, click the right mouse button on the CD drive icon and click 'Eject'.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 07, 2010 | IBM NetVista PC Desktop
My cd/dvd drive is not working.
You could reinstall the CD/DVD drive software, but it sounds like the CD/DVD drive is faulty. You'll need to replace the drive.
Jun 12, 2009 | Averatec 1000 Notebook
Need help
please try this on my computer right click and go to properties then click on it then go to device manager and click on it and look for your cd rom and right click on it and look for the remove the device and click yes and confirm it and then exit out and restart the computer then a found new hardware will pop up and reinstall it and then it will tell you that it is ready to use
Aug 20, 2008 | HP Pavilion dv9000z Notebook
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
My dvd cant eject
You need to provide more information.
A CD-ROM/DVD drive only needs power to eject a disc. It does not care if the drivers are installed, for that function, it only needs power.
If this is a new drive it might be a bad one. If this is a drive you have used before, it might have gone bad.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
If this is new drive, make sure it is connected correctly.
Nov 10, 2007 | LG GCC-4522B (0048231293594) CD-RW/DVD-ROM...
HP Pavilion dv4000 Notebook Logo
180 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
