Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load washer
Making a "bad bearing" sound when in the spin cycle
    President:
  • Maytag Master
  • 2,651 Answers
Thats generally a bad rear bearing, depending on age of the machine you may still have a warr on particular parts, not a fun job to do , without any warr. your looking at well over $600 in parts .In which case id be loookin for a new machine
Posted on Nov 09, 2008
Maytag Neptune MAH6700A Front Load Washer When it spins it makes a whining sound.
It should be making a whirling sound as it speeds up in the spin cycle. But if it getting to the point where it is so loud that you can't have a normal conversation, then the problem is that the bearings are gone and need to be replaced. It is an expensive repair since the mfg does not sell you just the bearings and you must buy a new rear tub. Get a few estimates if this is the case before deciding to repair or replace.
Feb 22, 2011 | Maytag Neptune MAH6700A Front Load Washer
Loud noise on spin cycle only clothes dry good
Sounds like your bearings and seal need replaced... See Neptune Bearing for information on the Maytag Neptune bearing and 12002022 seal kit. You can also rent a special tool kit that includes the bearings, 12002022 seal kit, bearing spacer, step by step DVD, etc.
I would not run neptune with bad bearings too prevent more damage to the Neptune spinner support, Motor drive system...
I hope this helps you...
Feb 01, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
My washer is making a horrible noise when it goes into the spin cycle. It sounds like it is about to explode.
The bearings on those washers go bad and the washer gets very loud during the spin cycle. It probably won't explode but for what it might cost to fix it you might want to blow it up yourself
Jul 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Loud Spin Cycle
im sorry,load spin cycle may be a bad spin bearing.remove lower back panel.look behind large black pully.if see rust ,water.metal fragments.thats it.cost a bunch to repair.ive done them 4 400 to 500$.God bless you ,tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Clicking noise
center bearing that holds the shaft is bad and lets the shaft move
Mar 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
