Question about Frigidaire FRT15B3A Top Freezer Refrigerator
Doesnt get cold
I have a fridge and the frige is warm but the freezer is as cold as the fridge should be
    Guru:
  • 93 Answers
You have the start of a defrost problem.  On this model they are know for bad connections to the defrost heater.   Read this article on defrost issues.  It will explain in detail what to do to repair your machine.
Thanks, Bill
Posted on Nov 09, 2008
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
Refrigerator doesnt get cold
you have a defrost issue, could be a timer, a board, a heater, or a bimetal. i suggest you call for service. 200 to 350 depending
Jan 03, 2012 | Kenmore Side by Side Refrigerator
Frezzer cold Frige warm
Hello LtCent,
I understand that your fridge is warm and your Feezer is cold. I have wrote a tip just about this porblem with refridgerators that will help you to fix the problem that you are having. Below is a link to the tip that you will need to follow in order to repair your unit.
Freezer Cold, Fridge Warm
Thank you for choosing FixYa.com
Justinbur167
May 17, 2011 | Refrigerators
I have a ge frige that the freezer works but frige is warm
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
I have a 2 door fridge, with the freezer at the bottom. My KIC fridge is 4 years old. My problem is that the freezer is cold, but the fridge is warm. I desperately need help, what cold this be ?
Pull it from against the wall, to let it breath. The condenser is usually in the back of the frige...It can also be a problem with the compressor or it's simply loosing freon. Make sure doors shut with a seal too. Try adjusting both thermostats too.
Apr 19, 2011 | Refrigerators
Freezer is cold 0F and frige is warm 70F
cleaned it and door was open for a while. closed door and and an hour later alarm went off. alarm now flashing and alarm light still on. temperature now at 53. freezer 33
Feb 01, 2010 | Maytag MFI2568AE Side by Side French Door...
Freezer is working good but the frige is 52
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Aug 17, 2009 | Refrigerators
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Magic chef gas/electric rv fridge freezer gets cold but fridge dosn't
Mod. R47 gas RV fridge 1973. It lights and gets cold (sometimes below freezing in the bottom of frige) then it starts to warm up above 55, but the flame is still burning high. I try to turn it down with the fridge thremostate and it stays the same. Is it the thermostate? If so where can I order one?
Jerry toolster@cableone.net
Jul 15, 2008 | Magic Chef Refrigerators
Frigidaire FRT15B3A Top Freezer Refrigerator Logo
83 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
