Question about Pioneer GM-7200M Car Audio Amplifier
Amp is on, Subwoofer works, but no sound.
I have a 800W pioneer amp, model GM-7200M, along with a new 12 inch pioneer subwoofer. I installed them both two days ago and they are brand new. It sounded great and everything worked. Then just recently the subwoofer didn't sound anymore. The subwoofer is ok and the amp light turns on. I don't understand what could have happened. I didn't disconnect it at all since it was installed. I checked to make sure everything was connected, but still no sound from the subwoofer only my speakers that aren't connected to my amp work.
    Scholar:
  • 119 Answers
Here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Posted on Nov 04, 2006
I have a pyle blue wave 12inch 800w subwoofer for a car hook up?
that just means it is dual channel.
if you have a stereo amp just run the left wire to one terminal and the right wire to the other terminal.
if your amp is mono run the wires to the first terminal and then from there to the second set of terminals.
PLEASE NOTE that by doing that you are bridging the speaker if the speaker was 4ohms to start with you just dropped it to 2 ohms so make sure your amp can handle that.
Dec 24, 2009 | Pyle 12" Molded Blue Cone High Power...
Pioneer GM-6200F amp appears to have blown, but fuses are intact
I have used Pioneer before but have not run
across this before.sounds like you may have
drove it a little to hard, and and zap one of your amps inside.Take the top off and look
around and smell.
Maybe This Will Help
Sep 09, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Protection mode on my amp
YEA CHECK THE OHMS ON THE SUB TO MAKE SURE THEY MATCH UP TO THE AMP JUS SOUNDS LIKE THE WIRING IS OUT OF PHASE.
Jun 15, 2009 | Pioneer GM-7200M Car Audio Amplifier
KEF PSW2000 subwoofer has power but no sound
to test a speaker you can hook up a batterie any where from AAA AA C D or a 9 volt batterie if the speaker makes a tone then it is fine and your problem is else where
Nov 03, 2008 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7200M 800 Watts Mono Amplifier
you Amp is overloading and going into protection mode. if it cuts out with the wire u were using first then their would be no need to upgrade the size of ur wire cause that would only be, doubling or trippling the power u are getting threw those wire now. bottom line the 2 subs u are using are obviously to much for the amp. try dropping the OHM's by connection the subs together and runnig just a single positive and negative to the amp! or just get a better amp
Mar 19, 2008 | Pioneer GM-7200M Car Audio Amplifier
Subwoofer help
You need to wire your Subs in Series. This way the current that passes through one has to pass through the other. Bridge your amp. and follow the wiring below.
Amp+ to Sub1+
Sub1- to Sub2+
Sub2- to Amp-
Nov 22, 2007 | Pioneer GM-7200M Car Audio Amplifier
Is it good
If you are using a GM-7200 amp, it should sound great. Both the amp and the subs are rated at 800 watts so be careful not to overload the bass by turning them on full power. It is good practice to have a slightly lower watt amp than the subwoofers. If you can power your rear speakers from the amp, that would take away some power to prevent the subs from overloading. Overall, you should get a nice THUMP!!
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
Need help
u should connect at least six 12" subwoofers (preferably 1000W each) to that pioneer amp of yours. Crank it up and enjoy. Your amp shouldn't cut off now. If it does cut off, you should change the fuse on your amp to a higher ampere.
More bass
Run one set of RCA lines from head unit to amps if you only have one set of pre-outs on the head unit, then at the amps, use an electronic crossover to split between the two amps, and this will also allow you to control what frequencies go to which amps/speakers. You should use one amp for the speakers and the higher power amp for the subwoofer. You should not try to connect both to the subwoofer. Use 4gauge cables if possible. If you have more questions, just ask.
Oct 29, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7200M Car Audio Amplifier Logo
1,157 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
