Question about Lands Phones
Display of iphone doesn't work it rings but i can't answer or see who's calling.
Bascially by screen is black and when i press the square button nothing comes up. The sounds work but I can't get it out of the black screen to unlock the phone
  • 2 more comments
  • Anonymous Nov 25, 2008
    same thing, nothing to add
  • Anonymous Jan 20, 2009
    one minute the display worked, the next it went black. I don't think the touch pad is operable either. Everything else works, apparently, 'cause I can hear the phone ring, the little "ding" when they leave a voice message, etc. Very frustrating.
  • join_hands Mar 27, 2009
    screen is totally black no display, it rings when i call but cant answer it need help
  • markhummel Apr 22, 2009
    Every so often, my phone will ring, and the screen remains black, and there is no way for me to answer the phone. The only thing I can do is click the button on the top (to lock it) so that it will go to voicemail. Then when I press the button to activate the screen, it will work.
5 Suggested Answers
  • 201 Answers
SOURCE: We cannot hear a ring on incoming calls
Sounds like your system defaulted. Only a few phones ring at system default and you may not have those ports connected. First, you need to figure out which Comdial Impact system you have. The phone will work on a few different Comdial systems. Find the main box and get a model number from that. You'll have to tackle re-programming ringing yourself or pay a local company to do it. If you do it yourself you will need the "programming and installation" manual specific for your system. A "user guide" will be of no use to you. You can search the net for "Comdial Digitech, Impact & Impression Programming & Installation Manual" Next, I would suggest a UPS backup for your system so this does not happen again. Unless you have a large carded system with dozens of phones, your phones require less power than a typical computer so a UPS made for a computer will be fine. The system will default either when the system memory battery goes too low or I have seen a few cases where power fluctuations will cause it (like when the power goes on-off-on-off rapidly in a storm) either way a UPS system with surge protection will help.
Posted on Aug 30, 2007
  • 201 Answers
SOURCE: Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Posted on Oct 18, 2007
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Posted on Jan 06, 2008
SOURCE: INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Posted on Apr 18, 2008
SOURCE: iphone screen wont turn on
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears.
Posted on Dec 23, 2008
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
My Iphone 3GS screen turned blank
First of all hard reset the iPhone (press menu and on/off together for 5sec). If that fails, there is a hardware issue. Apple should give you a replacement. If you're out warranty, you can try to open it and install a new logic board. You can get the part on Ebay or at iPhone Repair and there is a free guide that shows you how to open an iPhone and install parts at iPad Repair Guide.
Aug 10, 2009 | Apple iPhone 3G
My phone screen won't come on, it will ring if I call it, but the screen stays dark so I can't answer it... I have tried the small button on the top and the round button below the screen.
Try these resets:
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 27, 2009 | Apple iPhone 3G
Lcd
try rsetting the iPhone:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Jul 24, 2009 | Apple iPhone Smartphone
Iphone black screen & buttons "pressed" while on call
I tried a solution to a similar problem and it worked for this problem, which I was having too. All I did was remove the leather case that I used to protect the iPhone. Calling and the screen worked like normal after I took the phone out of the leather case. Try that.
Mar 03, 2009 | Apple iPhone 3G
CANT ANSWER IPHONE
you most likely have a hardware issue that needs to looked at by a pro at an apple store. you could also perform a reset by holding the power and home screen buttons until the phone resets.
Jan 25, 2009 | Apple iPhone Smartphone
Iphone screen wont turn on
Nov 19, 2008 | Apple iPhone 3G
Screen becomes blank when call comes
try jail brek thru ziphone and try restorg again for d touch scren 2 work
Nov 13, 2008 | Apple iPhone Smartphone
My iphone 1.1.3 doesn't work
press power button and home button together. press them 2gether for 10 secs. this is soft reboot.
this shud reboot the iphone.
u may need to put ur network settings again.
chao.
Jul 24, 2008 | Apple iPhone Smartphone
Lands Phones Logo
829 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
