Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
My cellphone's keypad doesnt fuction.what will i do?
Yesterday i was my hands and suddenly i put my cellphone on the soap dish noth knowing it was wet and has a water.when im done i noticed that my keypad wasnt funtion.what will i do now?
  • sam_Hollands Nov 09, 2008
    i can turn on the phone, but no keys work at all after that, i cannot get past my sim pin, so pointless phone now. mine broke after it being in the bathroom when i had a shower
    Problem Solver:
  • 5 Answers
Well hello.! water damage.?! the best possible thing you can do is sent it to motorola or get your service provider to send it away for you and they can fix it. but it may cost yu a bit.
Posted on Nov 14, 2008
Why does my dishwasher most of the time not desovle the dish soap
make sure when you load it that nothing is stopping the soap door from opening all the way,, most common mistake is loading a cutting board or tray in the front of the lower rack
Nov 20, 2015 | Frigidaire Dishwashers
Greasy hands cleanup / REALLY CLEAN HANDS
If you use strong hand cleaners and scrub brushes you can avoid both.
Soap will attach itself strongly to grease IF it is given a chance.
Typically people first wet their hands with water then add soap.
The water acts as a barrier to the soap to some degree.
Use any liquid dish soap. You only need a few CCs (cubic centimeters).
Apply the liquid soap to the palm of one hand and then rub your hands together
to spread the soap somewhat evenly. Then use your fingertips to work the soap into the grease for about 10 - 30 seconds per hand. The soap has now chemically bonded with the grease. Place your hands under running water while using a sponge with soft nylon mesh (usually white, not green) to remove the soap. The water will now bond to another part of the soap/dirt molecules and pull them off your hands with the help of the mesh.
This concept can be applied to bathing your body. A little soap, a lot of rub.
Frank in NC
on Oct 27, 2013 | Esca Tech Incorporated D-Lead D-Wipe...
Hi, Just moved into a place with a DU4500B Magic Chef. After a cycle there is still a clump of wet soap in the main wash cup dispenser and the dishes aren't clean. Yesterday I tried putting the soap in...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 04, 2010 | Magic Chef 24 in. DU4500 Built-in...
Water is running in and draining right back out. Leaving the dishes completely dry and dirty. I found a part laying on the floor when I took the cover off. I put it back where it came off of and now this...
Was it the float? try this empty machine put 1cup of vinegar or CLR and let it run through machine and clean jets and spray arm as well as soap dispenecer,You may want to try cascade they have rechanged it .Try this and let me know thanks
Jul 29, 2010 | Crosley 24 in. CDU600 Built-in Dishwasher
Kitchen Aid Dishwasher KUDS03ST We built our house and had this dishwasher sitting in the box for almost 2 yrs before finally using it. After finally installing it I find that occasionally the door to the...
i have seen a lot of dishwashers that have this problem if they have a flip open lid for the soap .. often its caused by the top adjustable tray blocking the soap door from opening .. i put a camera inside to figure out what was happening some cases all i had to do was raise the top basket .and make sure the basket is fully back before closing the main door .. it still blocks the soap door but allows it to open far enough to get the detergent washed out .....also i had to avoid putting large items in the corner where the dispenser is located .. they dont block the door but do reduce the water flow that could otherwise get into the cracked open soap door .. i reported this problem to my dealer .. and he stated that he didnt really want to know .. if he knows then he is obligated to do something about it .. which he claims he cant .. i demonstrated the problem on several brands at the store to whoever would listen .. some dishwashers have a sliding or rotating soap door .. those work better .. a few have a cut out in the top basket to clear the soap door .. .. the design of many washers are so similar that you might believe they are all made by the same manufacturer .with the same error in design . many seem to have that problem .. when the door doesnt open properly then the soap may become wet but not desolved .. somtimes it does partially desolve in the rince cycle .. i would think that is a hazzard .. you would have soap residue left on your dishes that you might ingest .. the dishes might look clean however so you may not even know anything was wrong ... letters to the manufacturers got me nowhere .. we struggled with that machine for a year .. we learned the tricks to make it work but during a big party our guests and relatives didnt know that .. there we were ready to serve with all dirty dishes ..after that happend a few times we bought another new dishwasher .. but the one delivered had the same problem .. what frustration .. so we sprung for a really good unit from bosch .. it has a sliding door and works perfectly .. very happy now ..
Oct 06, 2009 | KitchenAid Architect? II U SERIES KUDS03ST...
Kitchenaid KUDP01 not cleaning dishes
Remove the accumulator assembly and check the chopper to see whether it's clogged or damaged.
Jul 02, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
What will i do if my cellphone keypad dont function?
I think your stuck...Get a new phone as most cell companies have great deals and free phones...Good luck
Be careful with the new phone.
Apr 04, 2009 | Nokia 6300 Cell Phone
Soap left in cups when cycle is over
If the problem is that the dishwasher isn't filling with enough water, you should replace the water valve.
If it's getting enough water, but dishes have a white film on them or are still not getting clean, you may have hard water build up in your machine. Try to run a dishwasher cleaner thru it, or depending on how much buildup you have, you may need to take the dishwasher apart and clean it. I know JetDry puts a cleaner out, but I haven't personally tried it yet.
You can usually see white buildup inside the dishwasher if this is your problem.
Apr 07, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Continuous rinsing
Put 2 tablespoons of oil into the water at the bottom of the dishwasher it will help break up the suds. Sprinkle as well ordinary table salt liberally across the suds to disperse them. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the machine fill again, and repeat the process if necessary. Good luck !
May 25, 2006 | Hotpoint 23 in. BF41 Built-in Dishwasher
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
62 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
