Question about Sony Xplod XM-554ZR Car Audio Amplifier
Amp cuts out
My amp worked great for a day or 2 then it started cutting out and now it only hits about 4 or 5 times times then the thermal light comes on and it dont work until the light goes off. what is my problem? this sux
  • 56 Answers
Check your ground wire that's more than likely the problem.Try grounding it in a different spot make sure your ground is a paint and dirt free surface also make sure its directly metal to metal.
Posted on Nov 09, 2008
What caused my bosch matter saw to quit cutting in middle of the cut
Several possibles:
1) Load exceeded circuit amps. Breaker tripped.
2) Load exceeded saw amps. Reset tripped.
3) Wiring failure in saw.
4) Wiring failure in supply.
Time to start checking.
Note- if the blade is dull or the load on the saw is too great it will trip one of the breakers.
Mar 26, 2016 | Bosch Saws
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and...
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Sep 12, 2010 | Samsung HLT-5075S Television
Red thermal light on
well id say you have cooked your amp and or subs they can only take beatings for so long. show it no mercy it gives it back,does amp smell do subs smell borrow amp see if subs are ok if so it will be your amp.new one .keep the gain down??
Jun 11, 2009 | Rockford Fosgate Punch P550.2 2-Channel...
No sounds coming out of subwoofers
CHECK INSIDE UR SUBWOOFER BOX ...
Apr 11, 2009 | Pyle PLAM2300 Car Amp
When powered on protection light comes on
ya i would say its not grounded right
Mar 02, 2009 | Car Audio & Video
The Oven won't heat up
the thermal cut off located on the back of the oven has probably tripped,common problem. replace thermal cut off.
Dec 19, 2008 | Whirlpool RBS245PDS Electric Single Oven
Ford Freestar--engine cutting out
I'd like to come into contact with to purchase your vehicle
Nov 18, 2008 | 1990 Suzuki Swift
Sherwood Amplfier
Sounds like you like your music like me... LOUD. If you've done this a number of times, there are a few things that can happen:
1. You've blown the speakers... but you've said it operates for 2 seconds, then cuts out.
2. You've damaged the amplifier modules within the amp and they immediately overheat upon power-up. Does the music come back like 5 or 10 seconds after the unit cuts out?
3. Thermal switch has malfunctioned and just cuts off the power to the amplifier modules as soon as it sees any heat.
4. If you've gotten the amp really HOT during playing, it's possible that it's as simple as the amp modules are only intermittently connected (fatigued/stressed or cold solder joints) at the on the PCB. Just resolder the connections of the amp module to the PCB. I've seen that happen numerous times and that's where I'd place my money.
Jan 02, 2008 | Audio Players & Recorders
Amp cuts off
You may have a problem with the power source feeding the amp. You need to check the voltage across the amplifier's B+ and ground terminals when the amp is playing/cutting off. If it's dropping below ~11 volts, you need to determine why it's dropping so low.
Sep 18, 2007 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
My amp turns on then the music cuts in and out
check your main ground, if possible try to read voltage across making sure 12-14v present with load and some signal.
Aug 08, 2007 | Verge VGA285 Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
76 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
