Question about Cuisinart GR-4 Griddler
The right knob had come off!
The right knob which change the heat settings had come off and had a a small piece broken, I need replacement for the knob. Where can Iget that?
If your Griddler is still under warranty (3 yr warranty), Cuisinart will replace the entire unit for free. They do not replace knobs. (Cusinart knows if your warranty is valid by the serial number engraved in the bottom of your Griddler). You need to call Cuisart Customer Service at 1-800-726-0190 to get your Griddler replaced. You must pay a $10 shipping fee to get the new Griddler sent to your place, and you must return your broken one in the box they send you, and you pay for the return shipping.
Posted on Jul 21, 2009
Need replacement cups for turbo chopper
where can I find cups for my turbo chopper express mt1070.a little plastic knob has broken off. I have three mixers tryng get replacement cups. I have small I need the larger ones. I have writtened the company that makes them NO answer
Nov 15, 2013 | Cook's Essentials 19-piece 250-watt Turbo...
Climate control selection knob is broken The knob would not turn and when I pulled it off a piece of plastic droped out and now the knob turns freely but won't change the settings from AC to defrost or...
If I understand correctly, the same thing happened to me. It might just be the knob, if you can use pliers to rotate the metal piece where the knob connects then either buy a new knob or you could hot glue the old one in place. Just make sure you have it pointing in the right direction if you do.
Oct 08, 2011 | 2002 Buick Century
Control knob for heat/cold air only works on high
usually it is the fan speed resistor in the air box, I had the same problem with my wife's 2003 stratus sxt. I found that the resistor, that is what I call it, had broken a soldering point. The fan will only run on high if this piece is broken or burned out. It is in the air box usually near the blower motor behind the glove box. Generally has two or three small screws holdin it in
Jul 17, 2010 | 2003 Dodge Stratus
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Replacing the broken cup holder
First, you must remove the floor console bezel (the trim piece that surrounds the shifter knob). The proper method to remove this involves removing the shifter knob first. This is held in by a small set screw on the "radio" side of the knob. To remove the screw, you will need a small "hex-key" (also known as Allen key or Allen wrench). The proper size is 3mm, but you can get away with using a size 7/64" if you need to. Once loosened, I believe that the knob pulls right up and off. Make sure you do not lose the small screw. Also be careful not to accidentally contact the tip-top of the shifter while the knob is removed, as this may break off the small black plastic tip, which will require much more work to repair and/or replace the entire shifter.
Next, you should be able to remove the floor console bezel by prying gently and carefully on the corners and sides of the piece with a tool called a trim stick, or if you do not have this tool, you can get away with using a small, thin-tipped flat head screwdriver. However, this will almost surely cause some aesthetic damage to the edges of the trim.
Once this bezel is out of the way, (you shouldn't have to remove the electrical connectors on the underside of the bezel for this specific job) there are 2 screws holding down the bottom of the cupholder assembly. I believe these are both Torx - type screws, which will need either a T10, T15, or T20 screwdriver bit to remove(I'm sorry but I don't remember exactly which of the 3 sizes are used). After these 2 screws are removed, open the armrest. On the TOP of the FRONT of the armrest, just above the cupholders, are 2 more screws which should be the same as the 2 bottom screws. Remove these, then lift the cupholder assembly up and forward to remove it.
To install, simply reverse the above procedure.
Because this is my first solution posted on this site, I would love to have your feedback. Please let me know how everything goes with this project. Thank you!
Mitchell
May 23, 2009 | 2002 Dodge Intrepid
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
BROKEN MOUNT
WITHOUT KNOWING EXACTLY WHAT AND WHERE THE BREAK IS, HERE IS A POSSIBLE SOLUTION. EPOXY IS AN EXTREAMLY GOOD BONDING AGENT FOR PUTTING TWO PIECES BACK TOGTHER, SECURELY. AN EPOXY PRODUCT CALLED "J-B WELD" WHICH COMES IN TWO [2] SMALL TUBES BOUGHT LOCALLY AT HARDWARE STORES CAN BE USED TO BOND THE TWO BROKEN PIECES BACK TOGETHER...FOREVER. FOLLOW THE DIRECTIONS FOR MIXING, APPLY TO PIECES, CLAMP TOGETHER PIECES AND LET LET OVERNIGHT. WIPE OFF/CLEAN EXCESS EPOXY BEFORE IT SETS UP. THE NEXT DAY, DRESS UP THE AREA AS NEEDED FOR LOOKS AND OR FUNCTION. HOPE THIS HELPS.
Jul 28, 2008 | Meade Polaris 114EQ-D (36 x 114mm)...
Cuisinart GR-4 Griddler Logo
737 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
