Question about Panasonic DVD-RV32 DVD Player
DVD PROBLEM MY DVD-RV32 PLAYER IS SHOWING A HO7 ERROR, CAN YOU TELL ME WHY THIS IS COMING UP?
    Brigadier General:
  • 6,966 Answers
Often on Panasonic DVDs, error code H07 indicates that the spindle motor is not turning. The spindle motor is relatively small and expectedly wuld develop hardware problems over time. In some cases, a temporary remedy wold be to clean and lubricate the inside of the motor. Here is my post on similar problems with spindle motors of another electronic device, while here is an illustrated how to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 09, 2008
Error message HO7
HO7 is a fault condition with the Panasonic DVD players - it indicates that the traverse unit (laser and spindle motor assembly all in one part) has failed or burned out. The motor within it is usually the first part to fail and replacement of this complete device by authorised service agents is not cheap - around $200AUD just for the part plus labour! Unfortunately, the motor itself is not replaceable on its own; it MUST be ordered as a complete assembly with the new laser as part of it - if you decide to go ahead and get it repaired.
Feb 01, 2011 | Panasonic DVD-RV32 DVD Player
Does not play DVD and displays HO7. We have tried
This normally means the spindle motor is faulty,there is a little coupler and this splits,this will cause the machine not to load.
Oct 07, 2009 | Panasonic DVD-RV32 DVD Player
Screen says ho7, will not play dvd
This is a problem with your DVD Player .Please call to service center and tell the problem.They may either replace the system or rectify the problem in the same system itself.
Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
H07 error msg
Jul 12, 2009 | Panasonic DVD-RV32 DVD Player
It appears that it is saying that it is hot.
if your player is overheating, it is pretty much dead. try contacting Panasonic to at least report this, in-case they may know there is an issue.
overheating can be caused by an electrical-short and may eventually cause fire -failures which usually require a safety-recall and you will get a replacement.
if your player is on top of a Television, remove it and see if it still has the problem.
Jul 03, 2009 | Panasonic DVD-RV32 DVD Player
I have a Panasonic DVD player, model no: DVD-RV32, that is displaying the message "H07". What does this mean?
Here's the fix http://www.ledcar.com/pdvdh07/
I've replaced the motor once before on my 5 disk player to fix the HO7 error. The second time it appeared I tried the fix at the above link instead of going thru the hassel of the repair shop.
You may need to apply WD40 multiple times to cure the problem, depending on how stiff the rotation of the spindle feels. After the first application the player ran for about 5 minutes before the HO7 error reappeared. After the second application we watched an entire movie with no issues. we'll see how long this lasts. The fix was simple and hopefully wont have to be repeated soon.
Oct 21, 2008 | Panasonic Televison & Video
Getting "HO7" when loading disc
After calling Panasonic, they suggested pressing the reverse skip (<<) button, the pause button and the open/close button all at the same time. The DVD player will then say "initialize." Turn off the player and unplug it for about 1-2 minutes. Plug it back in and turn on the player and load a disc. If the HO7 error code pops back up, you need to take it to a dealership for service. Or, at the price of DVD players these days, just get a new one - which is where I'm going right now.
Aug 21, 2006 | Panasonic DVD-RV27 DVD Player
Awwwww The old HO7 code!! This code means that the spindle motor did not come up to speed and the only way to fix it is to first find out if its the driver servo circuit thats bad or the spindle motor itself is defective. If you know how to trouble shoot a motor speed control servo sure you can fix it, But theres no easy wand waving fix for this unit. Sorry. If its an older unit you want to consider buying a new one as it may not pay to estimate the unit and have it fixed . The balls in your court now my friend. Good Luck
Jul 26, 2006 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
331 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
