Question about Casio CFX-9850G Plus Calculator
Trigometric circular functions..
How to convert decimals into exact values? can actually the casio calculator work it out? for example : converting 1.570796327 to π/2
or just converting the π into the decimal value or vise versa.
  • Casio Master
  • 7,993 Answers
No the calculator cannot do that.
But if you do [2nd][Pi] [EXE] then just after [2nd][tan-1][2nd][Ans] you get 1. If you use the inverse trigonometric functions you will never have a value such as pi/4 or pi or pi/2. If angle unit is set to degrees you recover the exact values of the angles (they are integers anyway.
Hope it helps.
Posted on Sep 19, 2009
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
Calculate numerical value of fraction
A fraction is itself a value. If you want its decimal representation perform the division. On the Casio FX99ES, you can convert a fraction to its decimal representation by pressing the S<=>D key.
Jul 27, 2014 | Casio FX991ES Scientific Calculator 403...
Casio fx-82ms calculator does not give me an answer when i use the percentage button . example if i type 0.25/ 100% i get 0.25 instead of the right answer 25
Here is a sample of the percentage calculations that the calculator can perform. You will not see among them the conversion from decimals to percentages.
To convert from decimals to percents move the decimal mark 2 places to the right and append the % sign.
To convert from percents to decimals, move the decimal mark 2 places to the left.
Sep 28, 2013 | Casio FX-82MS Scientific Calculator
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
Entering,and working formulas with,Logarithms of Trigonometric Functions on a Casio fx-300MS.Converting Right Ascension to Ecliptic Longitude,without Latitude.Example:Log Cosine of Obliquity,(23.437778...
I am not sure there is a question expressed here. If you have a formula you want to use to calculate some quantity in it, state the formula, provide the known values and we will show you how to enter it. As to what it serves for, I for one do not need to know.
Sep 29, 2011 | Casio FX-300MS Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Why do i get fractions instead of decimals when i divide ?
In MthIO mode the calculator always try to display the exact rational answer if possible.
To convert a single value to decimal, press the S--D key. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Oct 30, 2010 | Casio FX-115ES Scientific Calculator
How do i convert a degrees/minutes/second problem using the Casio Fx-115ES calculator? Can you provide an example? Thanks ZH
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
Sep 25, 2010 | Casio FX-115ES Scientific Calculator
I have an fx 260 casio and I would like to know how to convert decimals to fractions using this calculator thanks
You can always convert a fraction to a decimal. The reverse may not alwas be possible.
Look at the example on the screen capture.
May 12, 2010 | Casio FX-260 Calculator
No the calculator cannot convert decimal values into excat values.
Hope it helps.
Nov 09, 2008 | Casio CFX 9850GA Plus Calculator
Casio CFX-9850G Plus Calculator Logo
241 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
