Question about Crosley CDG6000 Gas Dryer
My dryer isn't drying my clothes!
It starts off with warm air then turns to cold. If it is the thermostat, where is it located? It is a Crosley Gas Dryer model CDG6000W. It also makes a little rattling noise but then quits.thank you!
  • Anonymous Dec 27, 2008
    dryer is not heating
  • Anonymous Feb 02, 2009
    i have an LG he dryer it is 59 degrees here does that have anything to with it
  • Crosley Master
  • 2,651 Answers
Soundsmore like a coil kit thats gone bad,located atop the gas valve assy istelf, part number 279834 retails for about $20
Posted on Nov 09, 2008
Tumbles but does not dry
When you put your wet cloths in the dryer close the door. You should then turn on the dry cycle you wish, not the fluff option as there will be only air and gas dryer will not heat the cloths. Wait 30 ~ seconds after the dryer is turned on and listen for the gas to ignite and begin warming and drying the cloths. If you hear no bump sound like the ignition of the gas, then you have an ignition issue. It will require replacing the ignitor. All the best and good luck. Hope this helped.
Oct 02, 2012 | Maytag Neptune MDG5500AW Gas Dryer
I have a Roper gas dryer (RGS7646KQ2) which is not heating up to dry clothes. The drum turns and the timer works as well. It appears to be acting normally, except it is blowing cold air instead of warm...
You have a bad thermostat, flame sensor, thermal fuse, gas valve solenoids, or the high limit thermostat. Below is a video to walk you thru the diagnostic testing and repair.
Jan 03, 2011 | Roper RGS7646KQ Gas Dryer
I have a Whirlpool LGN2000PW gas dryer. The dryer will heat up when it is first started and get warm, but after a few minutes it cools right back down. We removed all the duct work in the basement leading...
if it still quits heating after a minute or so then its either a weak cycling thermostat or moisture sensor thermistor,both located on the blower housing, or the moisture sensor bars located near the door opening on the dryer,or it could be a high limit thermostat thats bad on the burner tube itself
Oct 14, 2010 | Dryers
Crosley cde6000w. was running fine, quit while drying clothes. machine was very warm to touch. still had power to control knob, buzzed when turn knob to end of cycle. let machine cool down and still will...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Sep 17, 2010 | Crosley CDE6000 Electric Dryer
I have a maytag dryer, model # MDG4000BWW. It has...
check the high limit/cycling switch thermostat located on the heat housing ,you will need to remove the front panel to access this,then, bypass the high-limit with a jumper wire and see if the flame stays on longer,if this doesn't help, then check the radiant senser on the tube also they get dirty,you can clean the senser eye or bypass this also and see if its weak,if not then replace the 2 gas coil valves on the gas valve body as these will get weak and shut off the gas supply
May 20, 2010 | Dryers
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
Dryer turns, heats, but takes forever to dry a load of clothes
you need to clean out the dryer,you have a block somewhere and if you don't take care of it you'll pop the thermal fuse or a need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is and remove the vent line and blow it out,if it's a long run from the back of the dryer to the outside flapper i use a leaf blower to blow out the vent line,make sure the outside duct is open and nothing is blocking the air flow before you blow it.also if it's a gas dryer you could have bad gas coils if the clothes are just warm instead of hot when the load is done,turn the dryer on when it's cold,after it runs for 15 to 30 minutes check to see if the flame is still liting,if it isn't you have bad gas coils located on top of the gas valve,the coils will work until they heat up and then they fail after a while,if i can help with anything else let me know,good luck you should do the clean out once a year anyway so you don't have a fire and so your dryer will run correctly
Mar 13, 2010 | Whirlpool Dryers
My dryer isn't drying my clothes. the air in the dryer is just warm.
Sounds like your problem is a faulty heating element or thermostats.
If you remove the back of the dryer, look for the air tube from the blower to the drum, normally inside of the air tube you will find the heating coil and the thermostats...
Good luck,
I hope this help you
Oct 04, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Crosley CDG6000 Gas Dryer Logo
560 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
