Electrolux front loading washer - door is locked, won't unlock
  • Anonymous Apr 17, 2009
    when i start the machine as usual, suddenly it stopped and the door can not be unlock
    how can we unlock the door?
    plz healp
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Posted on Oct 10, 2009
  • ASDV Feb 14, 2011
    This is going to sound really stupid but the same thing happened to mine. After running the cycle twice- the door was still locked. I tried the pause button (which usually would pop the door open mid cycle) and that didnt work. The cancel button didnt work. So I decided to simply UNPLUG the machine for a couple of minutes. When I plugged it back in- CLICK! the door unlocked immediately! Saved me a visit from the plumber :)
  • 2605 Answers
SOURCE: WFMC 3200 Front Load Washer: how do i unlock door? bosch washer was just deliv...
Hi, welcome to fixya. The emergency latch release is behind the small round panel below the main tub door. **Unplug the washer or turn off the breaker before attempting any suggestion given here please** To open the access door ( small round panel ) you'll require a small round needle shaped object or really narrow screwdriver. Put it in the small hole in the panel push in slightly and turn to about 6 o'clock...clockwise that is The small round cover should now come off and expose the pump with the string going through a hook on the pump housing. Be very careful as the edges are very sharp. A string will be threaded through the pump housing and you just need to pull it to open the main door. Let me know how you make out and also if you require further assistance with this problem. If you don't require further assistance and this indeed was helpful to you, please allow a moment to rate this solution I've given accordingly. Thank you for visiting "fixya" today and good luck. Macmarkus :)
Posted on May 22, 2010
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
  • 1294 Answers
SOURCE: kenmore front load washer shows door not locked
Try pressing 'end of cycle' for 3 seconds. You hear a click? Then wait for 2 minutes before trying the door, do not force door. No luck? Plug off the mains. Tilt machine backwards to unscrew 3 screws below the front panel, the kick panel. Slide the panel downwards & out.
Put your hand up towards the lock portion (inside the machine that is), you will feel a tear shaped thing, pull this thing a quarter of an inch down, the door will click open. Check to see that all wires are connected well.
Next try some WD40 on the door mechanism on machine, not on door, & try the door open/close a few times. Would be nice to know what service remember.(!)
Posted on Mar 13, 2009
  • 251 Answers
SOURCE: The door on the washer
Posted on Jun 24, 2011
  • 197 Answers
SOURCE: Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Posted on Sep 29, 2009
Electrolux front load washer door won't unlock. How do I get the door open? Model number: EIFLW55HIW0......unplugging didn't work
Disconnect power supply. Remove top panel.
Now is door lock accessible. Open door, remove door gasket from housing (not from tub), remove two screws and replace door lock.
Mar 02, 2017 | Electrolux Washing Machines
My Electrolux front load washer door will not unlock
Unplug the unit wait a minute than replug ,should open
Apr 04, 2016 | Electrolux AWF 1435 Front Load Washer
Electrolux EIFLW55HMB Front-Load Washer With IQ-Touch controls won't open
Try unpluging for a few minutes . wake the washer up by turning knob then at the same time press and hold start cancel error will display . take off top and you will find a tech sheet on left side and that should help. you can manually unlock the door after taking top off and reach down to door lock you will feel a plastic switch to pull
Feb 17, 2013 | Electrolux EIFLW55HMB Front-Load Washer...
I own a 1Q-Touch Front-Load Electrolux washing machine. The door won't open. What can I do?
Hello Elizabeth P Cochran - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Jan 15, 2013 | Electrolux EIED55HIW Electric Front Load...
E42 error code electrolux washing machine
Just followed the advice above by removing the 2 screws holding the top on and manually released the front load door. Now to figure out what part I need to replace the door lock mechanism and figure out how to do that.
Dec 20, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolus front load washer door won't open
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If the door does not open, then it sounds like the washer is possibly experiencing a communication problem with the control board, wiring failure or faulty door lock. Contact a professional to move forward accurately to properly diagnose/repair unit.
Nov 20, 2012 | Electrolux Eiflw55hiw Front Load Washer...
Electrolux washer door won't open
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
My Electrolux "Kelly Ripa" washer just completed a load, but did not unlock the door. How can I get the door open? The manual was no help.
check inside your pump filter first see if there is anything in there....this might be causeing your door to stay locked
May 08, 2010 | Whirlpool LHW0050PQ Front Load Washer
My front load washer has the door lock stuck and the door is open
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Feb 10, 2010 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
2,720 people viewed this question
Top Washing Machines Experts
