Question about GE PSC23NHN Side by Side Refrigerator
Monogram refrigerator side by side
The water dispenser ssometimes does not deliver water when the lever is pusher on the door. The filter was changed as well as the water valve. Sometimes if you hold the levaer in for a minute or two it will slowly drip and then start to work. other times it will work completely normal for and few days and then stop working. Help please Robert29
  • robert martin Oct 24, 2006
    I believe this model is a 27" monogram ferigerator freezer.
    thanks
  • deekron Nov 29, 2008
    Tried Catriver's solution. Still won't work. Dispenser tab definately set to water. Ice maker works as does ice dispenser.
    President:
  • 878 Answers
Robert, it almost sounds like your water reservoir is freezing some. This is located in the back of the lower section of the refrigerator behind the drawers. You can also check to make sure the water lever is making the switch and calling for water. The next time this happens, take a hair dryer to the water reservoir and go over it lightly back and forth. See if it makes the difference. Catriver..post back.
Posted on Oct 25, 2006
  • robert martin May 14, 2014
    The water line was freezing up cleaned refrigeration unit in the bottom go refrigerator have not had the problem since
Water dispenser not working
Then try replacing the dual water control valve. First look around the fresh food section door frame for the model number of your GE Monogram Here is a link to a service manual=> GE Monogram Serevice Manual PDF On page 15 of the service manual explains how to locate and change the water valve=> WR49X10043
I will be here should you have questions, Thanks Sea Breeze
Jan 25, 2013 | GE Monogram Side by Side Refrigerator
Water in the door not working.Solonoid clicking - filter replaced. Checked the lines. Ice maker works
There may be an issue with the water inlet valve, the dispenser's electronic control board or a dispenser water switch. Contact an appliance service company
Apr 13, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Water dispenser not working. The ice dispenser will work but the water will not. I held it down for 2 minutes to be sure there was no water in the line but its still not working. We also changed the filter...
Check in the back wall of the refrigerator section and confirm the water dispenser reservoir is not frozen.
Listen for the solenoid valve to click when actuating the water dispenser. If no click check the solenoid valve.
The wires for the switch are in the door hinge of the freezer. Confirm that they have not failed.
Hope this is a helps?
Jun 18, 2017 | GE Monogram Side by Side Refrigerator
Water dispenser is not working
check your water filter (change it) or a water valve in the back of the fridge. make sure it has power on it when the water lever is pushed. if there is power there then most likely its the valve.
Oct 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water from Water dispensor
Have you checked your water valve? I dont have your model number but you could have what you call a double water valve and one side of it may be out, alternately you may need to change your water filter if you havent done that yet. I have seen were the water stops dispensing first and then stops making ice. have you changed the filter lately? If not change it then if that doesnt work check water inlet valve...
May 12, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
G E Monogram side by side refregerator ZISB420DMC
I'm just a home owner, not an expert. Could be a frozen line. I think GE has had problems with this. I think they've retro-fitted their doors with better insulation that prevents the lines from freezing.
Jun 23, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Apr 14, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Water does not dispense from the door but there is water to the filter fitting
connect the water line in to the solenoid [with out the filter] to see if u dispensing water
Dec 01, 2007 | GE Monogram ZISx420DR 42-inch Side by Side...
GE PSC23NHN Side by Side Refrigerator Logo
122 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
