Question about Panasonic NN-P794SF Microwave Oven
Microwave turns off after 10-15 seconds.
My microwave turns off after ten-15 seconds. Everything in the control panel works fine. The microwave will run if set under 50%, but nothing gets hot.
  • chris bean
    chris bean Nov 22, 2008
    The fan runs, and the time it takes to turn off depends on the power setting. The higher the setting, the quicker it turns off. Also, the fan sound as if it's speed is inconsistent, like the power to the fan is fluctuating, seems like something is trying to draw power and causing the fan to slow. I am eventually going to tear into it, but I although I am familiar with capacitors and high voltage, I don't know what sensors or switches may contribute to the turning off. I basically need to know where to start.
  • chris bean
    chris bean Mar 29, 2010
    Thank's for the info. more than likely the sensor model, stainless steel mic with more programming option than my computer. we moved and it got thrown into storage before I could check it out, just pulled it out the other day, I am going to check it today. If I remember correctly it stops right around 16 seconds, won't make it to 22.
    Scholar:
  • 181 Answers
Make sure you hear the fan is still operating in your microwave. Next is to make sure the air intake grill on your microwave is not plugged up with air borne dust and dirt.
also.
for heating problem
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay
Posted on Nov 13, 2008
Testimonial: "first suggestion pointing out the possibility of a plugged vent. Such a simple idea, yet noone ever considers it."
  • Panasonic Master
  • 9,086 Answers
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
Ifit stops after 22 seconds, that means the controller has detected aproblem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 21, 2008
Testimonial: "Ok, I may be able to buila a hi-volt inverter, I have a friend who does windings for transformers... I will look into that"
  • William Miller
    William Miller Nov 23, 2008
    Okay, that would be a problem with the high-voltage inverter or the magnetron.
    You're right, it is what's called a loading effect due to a failing component.
Why is my microwave so erratic?
The internal controller may be defective.
Feb 06, 2015 | In Microwave Ovens
Microwave won't heat food. Everything else works on it
Most likely it is a bad magnetron tube (the heart of a microwave oven - it's the part that generates the microwaves). If the microwave oven is not under warranty or not covered by a service contract or home-repair contract, then it will probably cost more to fix it than it is worth.
Oct 17, 2014 | Frigidaire Microwave Ovens
No lights on control panel, but works fine.
there two power supply one for the Magnetron and other low voltage for display drivers and relay.
also it will have 2 fuses one of 10 Amps other for some 500MA replace the second one .
Mar 25, 2014 | Whirlpool RMC275PD Microwave Oven
Turntable does not turn
Possible that the belt has failed, or the motor is not working or that there is no power from the control panel to the motor.
You need to remove the bottom panel to observe this and confirm.
Feb 11, 2013 | Microwave Ovens
FMV156DCA turns on, cook indicator lights but not cooking, timer counts down fine too
Hello epinvegas - Try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, then it sounds like the microwave has a faulty magnetron, wiring failure or control board. Contact a professional to assist with the repairs.
Feb 07, 2013 | Frigidaire FMV156DC Microwave Oven
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
Everything is working fine on the microwave, except that it is not heating the food.
this a problem with your magnetron.some units have a five to ten year warranty.they need to be replaced by a service tech
Feb 23, 2010 | Amana Radarange Microwave Oven
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
I turn my microwave on and it turns off after about 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Dec 28, 2008 | Panasonic NN-S562 Microwave Oven
Cooktop Light / Night light
It is the control panel. You can actually just replace the circuit board on the control panel and it should fix this.
Nov 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
581 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
