Home | Canon | PowerShot SD870 IS Digital Camera | Line in the LCD screen
Canon PowerShot SD870 IS Digital Camera
Problem for Canon PowerShot SD870 IS Digital Camera
By jfirsching on Nov 09, 2008
There is a line going through the LCD screen that kind of looks like an etch a sketch. What should I do? I have never dropped the camera either.
Same Problem
May 25, 2009
-   I had the same problem the etch a scketch lines kept getting bigger and bigger until the whole screen turn completely black. I can not see any images. never dropped the camera either and only had the camera for a year.......help please!-   kvlmarysol
Apr 03, 2009
-   I have had the same problem i just got my LCD replaced. It was still under warranty through best buy. I am guessing this is a common problem on this camera? My camera is also a Canon SD870is -   Guest
Feb 26, 2009
-   small etch-a-sketch-like lines have appeared on LCD screen and are getting larger
-   Guest
Feb 26, 2009
-   small etch-a-sketch-like lines have appeared on LCD screen-   Guest
Feb 23, 2009
-   I have a thin black horizontal line on my lcd scren. The camera is Canon PowerShot SD 870 is.-   Guest
Best Solution
posted on Nov 09, 2008
Very Helpful)
voodoomox
Rank: Wiz  Canon Expert
Rating: 83%, 390 votes
there is a very strong possibility that a part of the film circuit of the LCD was loose and somehow totally lost connection due to shaking and other forms of physical trauma.
here are some links you may find helpful:
http://cannonlcdrepair.blogspot.com/
Changing a Canon Powershot LCD
Hope this helps out
Was this helpful?
Yes
No
Solution #2
posted on Dec 26, 2008
Not Rated)
mctc
Rank: Master
Rating: 90%, 11 votes
I would second the suggestion:
Canon Powershot LCD Replacement.
Screw around with the connection of the LCD and maybe you will get lucky.
Comments:
Dec 26, 2008
- oops bad at links:
canon lcd replacement.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot SD870 IS
Questions and Unsolved Problems for Canon PowerShot SD870 IS
Do you recommend Canon PowerShot SD870 IS Digital Camera?
Answer
Answer
how do we show video that has been recorded already cannon powershot sd870 is. which buttons do... (More)
Answer
when I take a shot close up the image is blurred. It seems to take a few seconds for the shot to be... (More)
Answer
I have a Canon SD870. I am getting replace battery with a fully charged battery. I have tried 2... (More)
Answer
My camera will no longer take a picture when a flash is needed. We can take pictures without flash,... (More)
Answer
Canon 870 when taking pictures outside they look fine in the lcd screen prior to shot then after... (More)
8 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 27, 2009
screen shows problems like an etch a sketch
Comment by Guest, posted on Jan 09, 2009
Small blob of defective pixels appeared, then the next day it grew many times larger. Was never dropped or exposed to water.
Comment by molow, posted on Jan 07, 2009
I think my LCD screen has partially burned-out pixels. It's no longer just a black etch-o-sketch line but now is more like a blob and growing slowly. What gives? (note: when downloaded, images are flawless.)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot SD870 IS...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
