Question about Danze D500558T Parma Shower w/ 4" Showerhead Trim Kit - Chrome
Danze shower kit
Just had installed the Danze Parma shower kit. Is it not possible to control the flow of the water? My husband says these faucets are common in Eurpoean hotels and only the water temp is ocntrolled but not the flow. Say it isn't so!!!
    Problem Solver:
  • 18 Answers
SORRY, ITS SO.... BUT GOOD FOR YOU THIS ISN'T MY FIRST RODEO... TELL YOUR HUSBAND TO ADD THIS TO HIS NEVER ENDING TO-DO LIST: YOU CAN ADD A SHOWER HEAD VALVE WHICH DEPENDING ON YOUR FINISH ONLY COSTS ABOUT 15 DOLLARS AND TAKES 2 MINUTES TO INSTALL. I ACTUALLY HAVE ONE ON MY DANZE VENETIAN BRONZE TUB AND SHOWER FAUCET FOR THE EXACT SAME REASON. YOU SIMPLY REMOVE THE SHOWER HEAD, THEN ADD THE VALVE, THEN ATTACH THE SHOWER HEAD TO THE VALVE. ADJUST FOR THE DESIRED PRESSURE. SORRY HUBBIE
Posted on Dec 29, 2009
  • 332 Answers
Your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Posted on Jun 23, 2009
Installed new Danze shower valve the water is on but will not come out why?
shut off your water and pull the cartridge out off unit...make sure you have no trash in cartridge...turn water on without cartridge in but only part way to see if you have water flow to value...then make sure no damage to cartridge or some of these have plugs that need removed on install of cartridge....you may need to remove test plug that is in there ....try this...good luck
May 09, 2012 | Danze & Single Handle Tub And Shower...
New installed no water flow?Water is flowing before and after the tub;so not a problem with valves or line???
If flow is slow to shower,pull showerhead,small watersaver hole and screen have garbage in it,teflon tape-rust sand etc Tub spout working fine?
Jan 28, 2011 | Danze Sheridan Tub & Shower Faucet
Shower valve has a thumping sound when other faucets or toilets are turned on and off.when you turn shut offs to danze shower valve off sound goes away.could this possibly be the plunger in the valve?
Vfiippone,
I have the same issue with a Danze Sonora shower Valve. I called Daze and they sent me a new cartridge. After installing it I have the same problem. I also put a surge arrester on my toilet which had little effect. If you find the cure please post it.
Nov 04, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
There's no set screw or plate covering the set screw. Not sure if handle just snaps on or what Danze Parma faucet
You didn't indicate exatcly what model. Check this link, and follow the install instructions. It tells you how to secure each type (3 different methods) One is a screw in the side with a cover over the screw.
http://www.danze.com/tech_specs.asp?show=D500058BN then click on install notes
Jul 04, 2010 | Danze & Single Handle Tub And Shower...
Water Flowing to Shower Head and the Spout Simultaneously
a solution is with the other different but same question.
Jun 02, 2010 | Danze D500558T Parma Shower w/ 4"...
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze pressure balance single handle shower faucet (D500558BN) pipes vibrate when adjusting hot and cold water.
it the valve is full of dirt or needs to replaced not all the time but i have fix many buy just cleaning it out or pipes are fasten down. try just cleaning.
Jun 10, 2009 | Danze D500558BN Parma Shower w/ 4"...
No water to single hole faucet after installation
the cartridge has trash in it.remove and clean,will work after that is done.
May 24, 2009 | Danze D222158 Parma Single Handle Hole...
Danze control valves producing loud water hammer
It sounds like your flow diverter isn't closing properly. Try removing the flow restrictors from the shower nozzle and see if that helps.
Apr 06, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Danze D500558T Parma Shower w/ 4" Showerhead Trim Kit - Chrome Logo
434 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Bill Boyd
Are you a Danze Home Expert? Answer questions, earn points and help others
