Question about Toshiba 57H82 57" Rear Projection Television
Toshiba 57H82 TV
Hi! I was reading the posts you made regarding the Hyper Module on the Toshiba 57H82. We are having what seems to be a similar problem with ours where it is almost a scrambled look on the screen that gradually improves over about 5-10 minutes. I am mechanically inclined so I can do quite a bit. It looks like based on the things I was reading that you can either replace the components inside this part or replace this part to resolve this problem. Is there a way to test if this is definitely the problem? If so, are there instructions available for making this repair inexpensively or should I have it repaired by a professional?
Thanks so much for the help!
  • svacox Nov 13, 2008
    Thanks! I spoke with someone and it sounds like they will just replace the board instead of messing with the caps. They actually stock the boards knowing they need them frequently enough. It's not cheap but I am not sure what the labor would be of replacing the caps or if they would consider it.
    Thanks for the info!
  • 934 Answers
You should ALWAYS consider having a professional do the job, just arm yourself with enough information about the potential repair to make an informed decision regarding your approval for it...
That said, yes,,,, a tech would pull the hyper module and test the caps in question using an esr meter (equivilent series resistance). If the esr is too high the cap is not dissipating voltage at a correct rate until its internal temp rises and allows for expansion inside. Cap that are critically high esr require a temp higher than their normal operating range and therefore always have the squiggly lines appear on the screen.
The caps in these are smd (surface mount) caps and are usually replaced using mini camcorder caps - bending both poles out vertically from the cap and trimming them to fit the platform. SMD's are so much more difficult to work with and I for one hate burning my fingers on a hot solder tip.
You can consider pulling the module and having it sent in for the repair as an option. On a scale of 1 to 10 and ten being the most difficult, this repair would be a 7...
Hope this helps.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Posted on Nov 13, 2008
Toshiba 57H82 problems
Val,
It's sent via Pando and you should get a link to it in your mail. To open it you'll need Pando, it's a free download if you don't already have it... The hyper module on that has about 10 caps that are common in that failure. If you need anything off board don't hesitate to ask.
Bill
PO Box 442
360-642-4993
Jan 07, 2009 | Toshiba 57H82 57" Rear Projection...
Service Manual
Jimmy,
Will send it out post haste... But be VERY careful inside the hyper module you can easily lift the traces when trying to remove the smd caps and ruin the module beyond repair...
Just send me a private mail and I'll return with the service manual.
Bill
Oct 14, 2008 | Toshiba 57H82 57" Rear Projection...
My 57 inch Probjection Toshibi had the best picture. The problem with it now is tearing in the picture and wavy horizontal vertical lines. Problem is most prominent with DVDs. Initially the picture is...
The hyper module is located in the metal box just behind the panel where all your cables plug into the tv. It is sodered to the board syou have to get under neath and melt the four places that the metal box is sodered. Once it's out you can either replace the whole board if you can find one. I can't seem to find it anywhere. you can also chage out all the 16v 10uf capacitors which is generally the source of the problem, but even these seem to be very difficult to locate now too.
Toshiba doesn't carry them anymore. Here is a link to the bulletin they put out becuase those capacitors are a known problem and failure point.
http://www.nesda-ohio.com/member/toshiba/PJTV200503%20Technical%20Bulletin.pdf
If you locate the board for replacement on the net please post a reply to this thread i'm in search of. Thx.
Aug 25, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba
Just pull the hyper module and send it in for rebuild - then simply reinstall it...
Bill
Jun 15, 2008 | Toshiba 57H82 57" Rear Projection...
Shakey screen
Needs to have the hyper module repaired... There are a group of caps on the hyper that need to be replaced... The hyper module is a stand-up board on the left looking in the back of the unit just behind the jack panel... Need to remove it and send in in for rebuild or attempt the repair yourself..
Bill
Jun 12, 2008 | Toshiba 57H82 57" Rear Projection...
Same Prolem with Toshiba 57H82 57
Just sent the manual via Pando - If you don't already have Pando you will need to download it first. It's a free download..
Bill
Apr 13, 2008 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57 in. Rear... Problem
Matt,
Sent a copy of the manual via Pando... Download Pando first, it's free...
Then download the manual from the link you're provided...
I repair hyper boards for $160.00 including the shipping back to you...
Bill
PO Box 442
Mar 20, 2008 | Toshiba 57H82 57" Rear Projection...
Tv only watchable through component Toshbia 57H82
this is a known problem with these toshiba tv's, they will do nothing to help you we should form a consumer group and complain to Washington! The part that needs to be replaced is a hyper pcb,pd0637and is available from Tritronics, in Miami Fl.phone #1-800-365-8030.the part cost me $263.00
Dec 06, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 57H82 57" Rear Projection Television Logo
87 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
