HDTV Visio Volume issue
I have a Vizio HDTV 720p 43inch conected with HDMI cable to comcast HD/DVR on HDMI 1 and an Upconvert DVD on HDMI2. the sound sucks. The only sound options I can see are HD and on/off. I cant believe these TVs dont have smart sound. Anyway the sound on regular tv shows isnt too bad but watching any type of movie is brutal. Either through the HD/DVR or the DVD I have to put the volume to 60 and still can hardly hear the dialogue, then get blasted with any kind of sound affects. So my movies get watched with the remote in hand..up to 60 down to 30 up to 60 down to 30...the whole damn time. Can you give any suggestions for set up please save my sanity!
    Problem Solver:
  • 8 Answers
Go in to the settings on the tv and change it to surround and then see what that does. that should fix it
Posted on Nov 09, 2008
Records & dubs but very poor resolution
You've got a Dish Network's HD DVR and a Toshiba 720P HDTV - so this part of the mix will maintain the HD pictures and high quality digital audio that you're used to seeing.
The trouble begins when you introduced the Magnavox VCR / DVD device. The highest quality video content that this device can record is the 480 type, regardless of the input or source quality - which in your case would be 720P via HDMI cables. 480 is considered "SD" or "standard definition". This is the weakest link in your setup and is responsible for your unsatisfactory results.
The Magnavox will "upconvert" to 1080 lines of resolution. The key here is the term "upconvert" True HD recordings are taken of a scene and capturing either 720 or 1080 lines of resolution in the image or video (such as a camera taking a photo or video); or recording the playback of a previously recorded 720 or 1080 lines of resolution source. Recording a 480 lines of resolution source with a an 720 or 1080 lines of resolution device will not make the image HD. The recording can not possibly be better than the original. In fact, due to losses, each generation of copy becomes worse and worse. Upconverting simply "fills in" the missing parts between the 480 source and 720 or 1080 output with what it "thinks" is missing data. The results are what you see on the screen. The original capture did not save more info that 480 lines of resolution so it is really impossible to improve it.
The recording can not ever exceed the quality of the original (the Dish Network DVR at 720 or more) and will only be as good as the weakest link (the Magnavox DVD / VCR at 480). Additionally, the moment you change from digital to analog, you lose quality instantly. Digital signals - both video and audio will always be faithfully reproduced do to error correcting technology, etc. that simply isn't available in the analog world.
You need to use a digital recorder capable of capturing and playing back of 720 or 1080 lines of resolution video and AC3 audio for optimum video and audio on a Blu Ray recorder or other device with hard drives or memory such as MP3 recorder. Otherwise you'll have to accept reduced quality of standard L & R analog audio and 480 lines of resolution of SD video. You can not expect HD audio and video if you try to save to equipment designed for SD / analog.
Dec 19, 2013 | Magnavox ZV427MG9 DVD Recorder VCR
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I am connecting Yamaha DVD player to the Vizio M420 NV via HDMI. i have a picture but no sound. how do I gain audio when using HDMI?
HDMI has both Audio and Video (High Definition Multimedia Interface) and should carry both. However, I had this problem with a client just the other day and it turned out that the firmware on his TV needed to be up[graded. Different model TV, but I believe you may need to download the latest software/firmware update via your PC and put it on a flash drive and then flash the firmware on your TV to get it to work. Sorry I don't have the specifics; I was stumped and the Time-Warner guy ended up doing it. I hope this at least sends you in the right direction.
James
Apr 17, 2011 | Vizio Televison & Video
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
Jan 21, 2010 | Vizio VX37L Television
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to Hook up HDMI from Comcast Motarola Cable Box
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
409 people viewed this question
Top Televison & Video Experts
Electro Med Services...
