Question about Kenmore 64902 Electric Dryer
Maytag pye 2300 dryer
Does this dryer use [2] 53-1182 thermal fuses and were are they located i was told done by the blower but there not there. thanx
  • projectfm Nov 10, 2008
    thank you very much. i located the fuse by the heating coil, but only found one 53-1182 fuse, it says to replace both but could only find one. so any additional info would be helpful to loacatr the second fuse. anyway thankyou very much.
    thank you i'll try again. i'm not very good at this sort of thing but who can afford techs at 90.00 an hour. project fm.
    President:
  • Kenmore Master
  • 2,651 Answers
They are actually located under he top along hte back wall, next to the heater asy, acessable from the top of unit. here is the thermal fuse kit number LA-1053
Posted on Nov 09, 2008
  • Ron Coons
    Ron Coons Nov 10, 2008
    the ki LA-1053 contains both thermostats, they are both locatd right there one on top of heater and one on the right side of heater
Locate thermal fuse on maytag neptune dryer model # mlg2000aww
The thermal fuse is located on the front cover over the blower wheel housing in the front of the dryer, the part # is 33001762,good luck
Aug 24, 2015 | Maytag Dryers
My dryer quit working in the middle of a cycle. Dont know what happen. Its a Maytag PYE 3360AYW dryer, we've had it for awhile.
Disconnect power38732b7.jpg882727e.jpge4ad6bc.jpg58c0a23.jpgThat thermal will blow and kill power to the door switch circuit. The dryer will no longer function till you replace the thermal fuse. 0bdf7e1.jpgFailure to temove lint will cause continued thermal fuse replacement.
Jul 27, 2010 | Maytag Dryers
Maytag dryer won't start
thermal fuse is the white platic fuse mounted to the exhaust about 6'' from the blower
easy to get to with a snub 1/4 '' drive
Sep 30, 2009 | Maytag Dryers
Maytag Performa Electric Dryer will not turn on
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer/control
Replace if defective (note: uncommon problem).
Jun 07, 2009 | Maytag Dryers
Maytag Model PYE 2300 AYW Dryer will not Start
How about the controller that turns everything on? Check for power to it? Relays(if any) working?
Aug 28, 2017 | Maytag PYE2300AY Electric Dryer
Don't know if you still need the info on this. Found mine mounted on the housing for the heater. Also goes by 36F14 20021
May 09, 2009 | Maytag PYE2300AY Electric Dryer
Maytag pye/g2300. dryer will not start.
A thermal fuse will not conduct electricity if it is bad. Take it off and check it with a continuity meter.
Apr 01, 2009 | Estate TEDX640JQ Electric Dryer
Need ohm readings for Maytag Performa Model PYE 3200AYW
Go to this site for info on your dryer type, you may find what you need there...
http://www.applianceaid.com/ww-and-mc.html
Jan 14, 2009 | Maytag PYE2300AY Electric Dryer
Will not turn on
the most common fault is a faulty thermal fuse heresd the part number for the replacement LA-1053 you can release the top assy by popping 2 clipps approx 6in. in from each side unde the front of the main top assy. the thermal fuse is located within the heater assy box direct;ly in the rear just under the main top. the kit includes a few tehremos and instructions depending on you rmodel
Nov 02, 2008 | Maytag Dryers
Kenmore 64902 Electric Dryer Logo
446 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
