Question about Quantum DLT 8000 DLT Tape Drive
I accidentally closed the window
Can you get it back?
  • 928 Answers
Unfortunately no but i sent you a message via the comment. Go to My profile then chats then view session to see my comment. I gave you my contact information and then ill have you contact me.
Posted on Nov 09, 2008
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
Disable shortcut dell latitude
reply-r Jans,
In Windows XP:
To turn off hot keys go to Start Button->Control Panel->Administrative Tools->Services and scroll down until you find the service name HID Input Service.
Double-left-click on this service and change the Startup Type to disabled. Click Apply and then OK. Close out your open windows and restart your computer and the hot keys should not trouble you.
Windows 7:
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2013 | Dell LATITUDE Computers & Internet
This file was not closed in previous session. Rolling back to last fully recorded transaction.
It's pretty much just like it says:
You either, didn't close out the program right by manually saving the last information you entered.
Or,the system shut down while the program was open, like a power failure or accidental reboot.
Did you have the task manager open, to close out programs,maybe to regain some memory, accidentally closing the program?
Something happen to close out that program before the last entered data was saved
Sep 25, 2010 | Intuit QuickBooks Pro 2002 (260102) for PC
I accidentally pulled the interior trunk release of 2008 volkswag
Try a screw driver,and release the trunk release at the same time and unsnap the latch,the latch thinks it is closed,because the latch never opened back up to allow the striker to go in it and trigger the latch to close,the latch is in closed mode,you will have to manually unlatch the latch sort of speak.
Apr 21, 2010 | 2008 Volkswagen Jetta
Accidentally closed trunk without letting auto
is the trunk lid latched at all
or is latched but not tight
Mar 10, 2010 | 2005 Ford Lincoln Continental
I need to close over 900 finder windows all at once. I was selecting approx 950 folders in the finder to transfer from one external hard drive to another and I accidentally opened all of the folders in...
What if you use system restore from safe mode or another admin account to restore the system back to a previous state. You could choose the last restore point available.
You don't mention what OS you're using, but I suspect this would work...see instructions here.
Or, you could press F8 at boot and try Last known good configuration. If that doesn't work, try booting with selective services enabled and only allow basic startup services to boot. Then you could use something like this to close all the applications....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Computers & Internet
2008 Pontiac G6 Convertible retractable top won't work
2007 Pontiac G6 retractable top engine swithed off while raising, top continued to close in compartment right side upper forward pad looking thing popped and the compartment would not close, however the top will raise and go back in place, cannot leave top in compartment since the trunk lid will not close over the stored top..........
Apr 25, 2009 | 2008 Pontiac G6 Sedan
The close ''X'' at the right top of the inbox page disappeared.
This windows icon only appears on the internet explorer window on the toolbar. SO I'm guessing you somehow accidentally got you IE window Floating and pushed up a bit to the point of NOT seeing the close box.
To resolve your problem findow the IE window tab on the start bar. right click it and select close. this will close the window and when you reopen itthe close box should be in a position that you can view.
If this fails then do the same thing but rather than select "Close" this time I want you to select "Maximize" this should stretch the window to cover the viewable screen bringing the close box into view.
If you still don't get your desired results please post back hear so I may help you further
Dave
Nov 17, 2008 | Audio Players & Recorders
DELETED MY SYSTEM FILE FROM C DRIVE
hi !
if you know how to slave your Hard Disk, try to slave it on other PC with the same windows OS you have. Then the file that you accidentally deleted to your Hard disk, OR you may clone all the System file in the Windows folder " C:\ WINDOWS ". in that way your OS will run back to it's normal process.
Oct 30, 2008 | Microsoft Windows XP Professional
Orbicam
Very easy solution to your problem
Use windows update to find the drivers..
Oct 20, 2008 | Acer Aspire 5580 Notebook
Open Questions:
Quantum DLT8000 Drivers not installing properly Something strange going on with the installation of the drivers on my DLT8000. I'm able to use the xTalk program to run tests and stuff on the tape drive from windows so I know it's working properly. However, this is what the device manager says: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) and it shows the little red exclamation point. Getting to this spot was difficult because of some issue with the INF file which (I guess) I was able to fix via this blog post: http://www.loosewireblog.com/2006/07/how_to_fix_a_br.html I added the [ClassInstall32] to the very end of the INF file that came with the downloaded drivers from the Quantum website. I was able to determine that the key name for this type of device is: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318} and sure enough, there is a subkey 0000 which contains all the info about my tape drive. This is what my setupapi.log file is showing: #-199 Executing "C:\WINDOWS\system32\rundll32.exe" with command line: rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{A270A48C-25F4-4B08-8975-00D9D0356FF2} #I060 Set selected driver. #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #-166 Device install function: DIF_SELECTBESTCOMPATDRV. #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device. #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device. #I060 Set selected driver. #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0 #-018 Searching for compatible ID(s): scsi\sequential,scsi\raw #I022 Found "SCSI\SequentialQUANTUM_DLT8000_________" in c:\documents and settings\mike\desktop\dltdriver\QntmDlt.inf; Device: "Quantum DLT8000 Tape Drive"; Driver: "Quantum DLT8000 Tape Drive"; Provider: "Quantum Corporation"; Mfg: "Quantum"; Section name: "qntmdrv_Inst". #I087 Driver node not trusted, rank changed from 0x00000001 to 0x00008001. #I023 Actual install section: [qntmdrv_Inst.NTx86]. Rank: 0x00008001. Effective driver date: 10/19/2006. #-166 Device install function: DIF_SELECTBESTCOMPATDRV. #I063 Selected driver installs from section [qntmdrv_Inst] in "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf". #I320 Class GUID of device remains: {6D807884-7D21-11CF-801C-08002BE10318}. #I060 Set selected driver. #I058 Selected best compatible driver. #-124 Doing copy-only install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030". #E366 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn, user said ok). Error 0x800b0100: No signature was present in the subject. #W187 Install failed, attempting to restore original files. #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #-024 Copying file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" to "C:\WINDOWS\system32\DRIVERS\QDLTx32.sys". #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #-166 Device install function: DIF_REGISTER_COINSTALLERS. #I056 Coinstallers registered. #-166 Device install function: DIF_INSTALLINTERFACES. #-011 Installing section [qntmdrv_Inst.NTx86.Interfaces] from "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf". #I054 Interfaces installed. #-166 Device install function: DIF_INSTALLDEVICE. #I123 Doing full install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030". #E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject. #I163 Device not started: Device has problem: 0x27: CM_PROB_DRIVER_FAILED_LOAD. #I121 Device install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030" finished successfully. That #I163 error is probably what the problem is but I don't know what to do now... Any help is greatly appreciated.
Nov 09, 2008 | Quantum DLT 8000 DLT Tape Drive
Quantum DLT 8000 DLT Tape Drive Logo
154 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
