Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
KitchenAid superba dishwasher leaking
My DW is leaking. It's a KitchenAid Superba with Stainless front and Black control panel across the top - possibly a KUDI02IRBS? The water is pouring out of a pipe connection on the left side - it's an inflow pipe. The connection from the pipe to the side panel has completely snapped. Could you please tell me if this is replaceable, if I can do it myself and where do I get the part from (Vancouver BC Canada) ? Thanks for any help you can give.
    President:
  • KitchenAid Master
  • 2,651 Answers
Heres a link to your part pook up, pg 6 number 4-5-6 is what i would assume your talkin about, its where the water comes into machine itslef, easy enought ot do your self, simply held on from the inside with gasket and nut. call local parts dist or whirlpool direct for parts
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208194206.pdf
Posted on Nov 09, 2008
I want to replace the white door panel with stainless steel
Have you checked with www.applianceart.com? They have faux stainless and real stainless options. PLus a ton of other choices there.
Feb 21, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
KitchenAid Superba series has water in the bottom.
kitchen aid has a drain valve on older models and that could be the problem newer models.the motor goes other dir to drain . yu need to ck the drain out let to disposal an make sure ist clear and hose is not kinked . also be sure there is a drain loop at that point . this prevents back up and bad ordor in dw . hope this helps . mm
Dec 08, 2009 | Washing Machines
Superba Dishwasher power loss
could be several things... wiring to DW might be problem, Control might be bad. Is door closing tight?
Oct 16, 2009 | Dishwashers
How do you clean the front door glass in between the pains of our range... it is a superba...
You must remove the galss assembly. Usually you remove the handle and that loosens the glass assembly and the door front. Take it off the range and lay the door on the floor to make it easier.
Sep 22, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Rust on front of my GE Profile dishwasher panel
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish will remove the rust and pacify the surface. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Aug 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba kuds01ijbs0 rinse only light flashes
hi! there only the solenoid valve for water supply has reciving a source to activate by your timer,the sequence operation of diswashing process has ben ignore,so the faulty was on your timer switch.disabling the motor to function you can check this in your panel front control.be sure to switch of power and service valve for water supply before checking.the fig are just sample as reference
to your dishwasher control panel so you can start where are those control.cb7265c.jpg
open front cover using screw driver,loosen screw holding timer control circuit try to clean all contact if defective replace timer
circuit board,check also the moter control timer using multitester
ser to R1 taking the continuity of terminal and contact point and some multi relay,solenoid valve supply.replace any defective part and reasemble parts after replacement,regard and have a nice day
Mar 20, 2009 | KitchenAid 23 in. KUDD01DPPA Stainless...
Want to replace dishwasher panel with stainless steel
Yes indeed! If you know the measurements, you can buy a stainless panel from www.applianceart.com cut to any size you would like. THey also have a cheaper "faux" stainless option too. Many colors and designs as well.
Mar 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Dishwasher stopped working during rinsing cycle.
1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse with wiring harness supplied with it.
Good luck
Vlad
First Choice Appliance
Jan 05, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Model Number
Open the drawer or bottom cover panel and look on the facing where the door closes to
Dec 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
483 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
