Question about Canon PowerShot S2 IS Digital Camera
Canon powershot s2 Is
Everything was dandy until my batteries died. i went to the store and bought new ones, loaded them up and now i can't use it. it beeps 4 times every time i try to snap a shot and across the top of the screen it says, "naming error". what do i do?
  • 3 more comments
  • Anonymous Dec 14, 2007
    Recharge batteries. That was the message. So, I charged them. The next time I went to use the camera, same thing. So I bought new rechargeable batteries, then a new charger. Same problem. Now I know it's the camera. Canon no help. This is my last Canon produtt.
  • jwithing Dec 25, 2007
    When I turn the camera on I received the message, across the top of the display screen, "NAMING ERROR". Don't know what to do - HELP??
    Camera is a Canon Powershot 450.
    Thanks
    Judy
    judywithington@rcn.com
  • nevinai Apr 19, 2008
    My camera worked for a while, but then at one point the batteries died after only an hour of use. Each time I replaced the batteries it would work for a shorter period of time, and now I can't get it to turn on at all even after putting in brand new batteries. I switched from regular to the rechargeable that are meant for use with cameras but it has not made a difference.
    I didn't realize when I bought it that it ran on regular batteries and didn't have a charger, I just assumed it had a charger because it is absolutely-fu**ing-ridiculous for a camera this size not to have a charger. My mistake. I should have taken it back and got something else.
  • Anonymous May 22, 2009
    same thing!
  • siqingwei May 11, 2010
    Daniel:
    for your Solution#2:
    what if I cannot even turn on the camera -- how do I go about reset the camera?
    When I turn it on -- the orange lights came on for a few sec, info shows "change battery"/lens does not extend -- then light goes out
    appreciate your help
I just fixed mine. Put your memory card into your computer. Right click on it. Choose format. Reformat the memory card. You WILL lose all pictures stored on it.
Before putting the memory card into your camera, do the following.
Go to MENU and choose RESET ALL.
Choose reset to original settings.
When camera is done doing so, turn camera off.
Reinsert memory card after it is done being formated in your pc.
Then your camera and memory card should work great again. I just did it on my Canon Powershot A620.
Posted on Mar 22, 2010
HI guys I also faced the same problem .Guys simply format the SD card.It is because of the memory card.Dont worry simply delete all the older pix.And use it in the camera
Hrishikesh Molkar
Posted on Nov 26, 2009
From "Tom Friend" on dpchallenge.com
Steps to try to correct the "change battery" problem with S2 IS camera:
1. Reset the camera, (turn on, hold down 'MENU' for 5 seconds, answer 'OK'.
2. Remove the date/time battery (button cell in the battery compartment) for a minute.
3. Important: Insert freshly charged batteries into the camera.
Posted on Aug 31, 2008
Solution #2 worked!! Thanx Daniel!
Posted on Sep 12, 2008
I just got this 'naming error' for the first time today and I've had my canon for 5 years. It's a new 2GB card I bought and I can still see all of my pics. Does anyone have any idea how to fix this problem? I'm travelling for a while and don't have the space to let this happen.
Posted on Apr 19, 2008
Find out how to reset the camera and reset it
Posted on Jun 27, 2007
SOURCE:
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
Canon Powershot S2 IS Digital Canera says to change the batteries even with new batteries in
Check that your battery terminals are clean and that none of them are loose. You may also need to change an internal battery, the one that saves the date & time.
Apr 10, 2010 | Canon PowerShot S2 IS Digital Camera
What battery do I need
The battery for the PowerShot G3 is the Canon BP-511A.
Mar 26, 2010 | Canon Accessory Kit (ACCS) Battery Case...
Newly charged batteries don't work
try going to canon.com and download the firmware update for your camer, it will work fine after that
Jun 26, 2009 | Canon PowerShot S2 IS Digital Camera
Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jun 22, 2009 | Canon Powershot A1000IS Digital Camera
View window is black
There is a temporary fix that works sometimes but eventually it will stop working alltogether. If canon can't help, might try this:
<http://cgi.ebay.com/Repair-blank-black-pictures-S2IS-canon-powershot-S2-IS_W0QQitemZ300293064869QQcmdZViewItemQQptZDigital_Cameras?hash=item300293064869&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50>
Jun 28, 2008 | Canon PowerShot S2 IS Digital Camera
Canon Power Shot S2 IS Digital camera does not turn on
Call Canon tech support. It's free support and you may end up coming out cheaper by upgrading your camera through their Canon Loyalty program than having it repaired.
Mar 22, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
2,314 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
