Question about Frigidaire Dryers
Dryer keeps blowing a breaker - Frigidaire Dryers
    Scholar:
  • 60 Answers
If the dryer does not run it could be a number of things including: timer, start switch, door switch, thermal fuse, high limit thermostat, cycling thermostat, timer motor, cord. or dryer motor.
The start switch, door switch, thermal fuse, high limit thrmosta and cycling thermostat are most common and can all be checked for continuity with a ohm meter. (they should have continuity if not that parts is the problem)
If you have the knowledge to read wiring diagrams you can find the 2 leads from the timer that supply the power out of the timer remove the wires and set the timer to the timed cycle and you should have continuity through those 2 wires if not suspect the timer.
If you hear a loud buzzing or if you have to "help" the drum start to turn it could indicate a bad motor.
go here for parts breakdown to refer to;
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=502871
go here for repair manual
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Dryer-manual-for-Frigidairl-gas-and-electric-dryers-item-number-AP3873780.aspx
Posted on Nov 09, 2008
Get a new dryer cord
2 Suggested Answers
  • 2468 Answers
SOURCE: kenmore electric dryer keeps blowing circuit breaker
either the heating element has sagged when it gets hot and is now shorting out to the dryer heater case,or possibly a defective drum motors bearings getting tigt or the motor windings are shorting out and drawing excessive current,or even possibly a wire vibrating during operation and shorting out at a wear spot on the insulation,but most likely if it shorts out at a preset time after start it would be one of the first two problems listed above,
Posted on Apr 21, 2012
Mt Moffat clothes dryer keeps blowing thier own fusses
You have heat sensors on the Heating Element. If one allows the heat to get to high it can trip the Breaker. It more than likely is a bad Circuit Breaker in the Breaker Box. These can go bad. It is a Double switch, one is for the heat, one is for the Motor.
Jan 18, 2013 | Dryers
Kenmore electric dryer keeps blowing circuit breaker
Apr 20, 2012 | Kenmore 400 6942 Dryer
I have a Kenmore Series 70 Dryer and it keeps blowing the main breaker on the electricity panel - the main fuse is 20 amps do i have a dryer or fuse issue ?
Your dryer needs at least a 30 amp breaker to operate correctly. Changing to a 30 amp breaker should solve your problem. Hope this helps
Sep 01, 2011 | Dryers
My dryer is dead worked fine yesterday>
Check your breakers or fuses. One of them could be blown or thrown. If it is keep doing that then you have wiring issues inside the dryer causing the fuses or breakers to blow.
Apr 30, 2011 | Dryers
I have a sears kenmore gas dryer model 87592820 it keeps blowing the breaker. It was running about 1 min. then a spark flew out and it tripped the breaker. When I reset the breaker it continues to trip it....
This sounds like you have a wire that rubbed through and is shorting out...
open up the back or where you saw the sparks come from and you will easily see the burnt mark...then you can fix it...
Do not keep trying the breaker... it is tripping to protect you and keep you safe.
heatman101
Sep 28, 2010 | Dryers
My neptune electric dryer keep blowing the breaker after ten min
If the dryer is running then blows the breaker , then it is not in the electric circuit, There is a fault in the dryer itself. If it blows the circuit at the same place in the cycle each time then there could be some fault in the heating coil or in the timer circuitry.
Dec 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
It keeps blowing the breaker
hello it sound like a bad earth check for any loose wires if ok then it could be the motor gone down to earth
shaun
Aug 31, 2009 | Kenmore Elite HE4 Electric Dryer
Maytag dryer MDE6000AYW keeps blowing the fuse in the panel box, what is wrong? I reset the fuse in the panel box and turn the dryer right back on and it will start right back up. It may or may not blow...
Bad breaker in the panel box.Loose wires at the breaker. Loose connection in the wall outlet. Loose connection at the dryer cord terminal. Bad cord.
One or more of the above.
Jul 05, 2009 | Maytag MDE6000 Dryer
Dryers Logo
182 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
