Question about Samsung HP-T4254 42 in. Plasma Television
TV flickering on and off
I have the problem with my TV flickering on and off. At first its on for 5 minutes then starts turning off and on. I have a digital cable boxwith Hi Def on it from Cox Cable, aswell as a Panasonic Surround Sound.All of them have their power sources connected to a surge protector andfrom their to the wall outlet. Please let me know if you need moreinformation and if so what kind of information. Thanks
    Scholar:
  • 93 Answers
I will unplug the TV power cord from the surge protector and have it connect directly to the outlet first and see if this will resolve the issue,small chance but worth to try.
Secondly,if you have an universal remote control for your system,you need to let me know what kind!
Now,if you don't have an universal remote control that had programmed to either IR or RF,and you have the TV power cord connected directly to the outlet and still having the same issue,it is time for a TV repair specialist to check it out;however,if you have your TV more than 7-10 years,you might consider buying a new one,cause cost of labor and part might not be worth to fix it.
Soultiondoct
Posted on Nov 11, 2008
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
AKAI Rear projection TV
Try using different inputs besides the RF input. Connect your PS2 and DVD player using component inputs. With two component inputs, there's no reason in the world not to do this.
Feb 28, 2008 | Akai PT4298HD Rear Projection Television
TV problems?
you could have a couple of problems here
sounds like your tuner is bad but it may be repairable
useually when you first turn your tv on its cold then heats up and more then likley solder joints start to open uafter warm up then if you shut your tv off for a few sec. turn on it may be okay till solder joint get hot then open up tou need your tv reaired or buy new one
Feb 17, 2008 | Televison & Video
Tv PROBLEM
More than likely you have loose connections on the power supply board. Fixing the connections should take care of the problem.
Oct 03, 2007 | RCA F35731MB 35" TV
Flicker after warm up
Arcing noise suggests HV leak--get a tech to look at set!
Oct 03, 2007 | RCA D52W19 52" Rear Projection Television
Samsung HP-T4254 42 in. Plasma Television Logo
271 people viewed this question
Henry  Thomas
Henry Thomas
