Question about Sony Playstation 3 (PS3) Console
Jammed DVD PS3, DVD is jammed, how do you remove? The manual offers no troubleshooting help. (2 year olds do the darndest of things) Thanks, Robin
Lol i used tweeser to grab the disk worked for me my kids are crazy
Posted on Nov 09, 2008
Dvd player is jammed and wont open can you help
try taking the outside cover off then you might be able to manually open it .
Jan 28, 2015 | Philips DVDR3440H DVD Recorder/HDD...
My printer says I have paper jam, please remove. but i have only been able to remove partial pieces. How do I get at the rest left in a spot I can not reach
Here's a link from which you should be able to download the online manual with a troubleshooting section that includes specific instructions on clearing a paper jam. See also this page, as I have no great confidence in the links I get from canon, their website is so backwards. If you choose the service and support option, then ask "how do I clear a paper jam" you'll see the instructions they offer.
Issue: Paper is jammed inside the printer
Solution: Remove foreign object from paper feed area (MP130)
Remove foreign object from paper feed path If error message
  • [PLEASE CLEAR PAPER JAM AND PRESS [OK]] or
  • [CHECK PRINTER]
is displayed, follow this procedure to remove paper or obstructions from the machine. Clearing Jams In The Paper Output Tray:
  1. Gently pull any jammed paper out of the Paper Output Tray.
  2. Press .
  3. If you cannot see any jammed paper in the Paper Output Tray, remove it from the machine's interior.
    1. Press to power off the machine.
    2. Lift up the Scan Unit until it locks into place.
    3. Open the Paper Output Tray.
    4. Look in the print area for an obstruction (such as a paper clip, staple, tape, etc.) and then remove it.
  4. If you are printing from an application software, follow the instructions displayed on your computer.
Clearing Jams From The Auto Sheet Feeder:
  1. Gently pull out any jammed paper from the Auto Sheet Feeder.
  2. Press .
  3. If you are printing from an application software, follow the instructions displayed on your computer.
Sorry I can't offer you much more, but just try to get all the bits out. Sometimes a pointy tool on a vacuum will help. Otherwise, maybe you can wrap and tape a post-it note around a popsicle stick or something to reach the paper and try to coax it out, or maybe a bit of folded tape on the end of a ruler or something like that. Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I hv a JVC th-s3 dvd player who's dvd tray is locked. none of the solutions on this forum hv worked. pls help. thanks. chris
You have to remove the changer assy. See why it's jammed and retime it. I have seen a lot of these with jammed changers. If you remove the dvd assy from the bottom there are 2 gear sets to the side. 1 moves trays up and down and the other draws tray in and loads the disc. All I can say is if you are mechanically inclined you can figure it out. If not have it serviced.
Jan 01, 2010 | JVC TH-S3 System
My 2 year old jammed 2 or more disc inside my ps3 what should I do?
at the back of the ps3 theres on and off switch turn on at the back then press and hold for 5 sec the eject button
Oct 13, 2009 | Sony Playstation 3 (PS3) Console
DVD won't play and door won't open
Since you purchased a Bose system, I can only assume that you know nothing about electronics.  Therefore, I would suggest you take it to a repairman rather than try to open it.
Or, you could just buy something that isn't Bose for 1/10th the price and get twice the quality.
If you must be adventurous, you can open the unit and try to figure out what is jammed up and manually remove the DVD.  Again, if you know nothing about electronics, this could get you very hurt or killed.
Jul 08, 2009 | Bose 3 2 1 GSX System
My daughter jammed 3 or 4 DVDs into the game console. Once I removed them the game will not allow me to feed games of DVDs into the machine
the rails the dvd's insertion wheels ride on have jumped off track. it needs to be dissasembled and put back on track. its actually pretty easy to fix but it is a very delicate mechanism. I offer that repair for $60. Notify me if you need help. thanks
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
Fridgidaire side by side Ice cube jam
You can adjust the size of the ice cubes . if the cudes are too small or to big . they can get jammed... the timing screw is under the head cover clockwise is smaller . turn it one turn at a time... hope it helps
Jul 15, 2008 | Frigidaire FRS26R4A Side by Side...
Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
Jul 07, 2008 | HP Officejet 6310 All-In-One InkJet...
Jammed disk in PS3
You will have to break down the unit, take the cover off the BRD (blue ray drive) and physically remove the disc. It's probably the stepper motor on the slide assembly jammed. Good luck.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
2 disks stuck in one slot of DVD player
Looks like it will have to come apart. Can you see how? Usually the top/side casing is simply 5/6 screws 2 each side and 1/2 at the back then slide back away from the from panel. Technical help at Panasonic may be helpful.
Jul 02, 2007 | Panasonic SC-HT680 System
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
