Question about Car Audio & Video
Car starts but dies within seconds
The will start but dies within seconds tried changing the fuel filter, but that was not the problem.
  • Anonymous Dec 18, 2008
    i have the same problem...i put more oil in and it ran for a day.
    Problem Solver:
Is your car one that uses a Mass Airflow sensor? if it is you more than likely have a cracked air tube. This is the tube that comes off the air filter box and mounts to the throttle body.
Posted on Dec 22, 2008
I have the same problem. I put 2 quarts of oil in it and it ran for a day.
Posted on Dec 18, 2008
I have a 1993 Jeep Grand cherokee laredo with the 4.0 its starts for only a few seconds and dies changed the fuel pump and fuel filter and the sercurity light doesn't come on im stumped any help ?
Check the crankshaft position sensor, i have repaired 3 Jeeps (after the owner spent a lot of time and money replacing fuel pumps,TPS, and many other items) then got frustrated, brought it to me and within an hour it was running fine with a new CPS
Apr 04, 2013 | Cars & Trucks
2007 NISSAN QUEST It starts and then dies within 2-3 seconds.
hello good day, reverse your air filter, make the bottom to top,, if is not work change the high tension wires
Mar 07, 2013 | 2007 Nissan Quest 3.5 Minivan
My nissan murano wont start after oil change
Sounds like it could be a fuel pressure problem so i would check the pressure to see if its within the specs first and go from there.
Oct 31, 2012 | 2007 Nissan Murano 3.5
I AM RESTORING A T020 MF. I REPLACED ALL WIRING AND IGNITION SYSTEM AND REBUILT THE CARBURATOR, AND ADJUSTED IT TO SPECS. I GOT IT TO START RIGHT AWAY AND IT SOUNDS GREAT. HOWEVER, IT WILL ONLY RUN FOR...
Ok a quick check. When the engine cuts out and you go for restart it dies within 5 seconds. Next time put the ignition at position 2 (on but not starting) and wait one minute, then start the car. If the engine again runs for 30 seconds before cutting off this tells you its is a fuel problem. If the fuel is supplied slowly it fills the carburettor fuel bowls and when the car starts it quickly uses up these local reservoirs of fuel faster than they can be replenished. When you try to restart immediately there is only a tiny amount of fuel and so it used up almost immediately. By leaving the ignition on 2 for while it gives the pump time to fill the carburettor bowls and this takes a while longer to run down when the engine starts. Just before moving on does the car have a choke OK remove the low tension connection to the coil, basically remove any chance of a spark. Put a big old towel around the carb. Now remove the fuel line at the carburettor and put ignition on 2 to engage the starter pump. Listen to pump operation and look at the rate of fuel being pushed from the disconnected fuel pipe. If the flow is slow check on pump and filters.
Sep 13, 2010 | Ford F-100 Cars & Trucks
Cars starts and dies five seconds later
try changing the fuel filter. with that many miles on it could be clogged. most people forget all about the fuel filter which is typically on the passenger side on the frame rail near the tire well.
Nov 28, 2009 | 2006 Nissan Altima
I have a 93 nissan altima with fuel issues
have you tried changing the fuel filter
Jun 05, 2009 | 1993 Nissan Altima
Starting
Yes, it sound like a fuel problem. It's a 5 speed, have you tried push starting it? Try that and if it starts but within 20-120 seconds dies than you have a bad fuel pump or a clogged fuel filter. The filter would be seen as you were to let the car sit for an hour or so and try starting it. It would run and again shortly after die. You may have to bring it to a garage. Good luck.
May 10, 2009 | 1999 Volkswagen Cabrio
1991 Mazda MX-6 starts and it dies within 30 seconds or less.
Check to see fi your fuel pump is functioning, also change the fuel filter. I had this same problem on a 1984 626. While i waited for the car to restart fuel would seep into the line to allow for the enging to startbe that was it.
Dec 25, 2008 | 1989 Mazda MX-6
Car Audio & Video Logo
55 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
