Question about Mitsubishi VS-45607 45" Rear Projection Television
Locked ext inputs
I ttied to connect a dvd player in the ext inputs were locked and i should put in a code to unlock. I did not lock so I have no code. is there a universal code? or a reset button? I cant use my rca inputs.
  • 3 more comments
  • hearrt1991 Nov 11, 2007
    I can't connect dvd player because ext are locked
  • Anonymous Dec 25, 2007
    locked inputs
  • ds1965 Dec 29, 2007
    I have the same problem. Could not find a manual on the web either.
  • Manatees2003 Feb 15, 2009
    ITS SAYS TO ENTER A FOUR DIGIT CODE TO UNLOCK BUT I DONT KNOW THE CODE
  • wsjan Feb 20, 2009
    mitsubishi vs-5020r - I am trying to connect a dvd-r/vcr to my tv but the input is locked and I have no idea what the code is to unlock it. Is there a universal code that I can use to unlock the input?
    Champion:
  • 206 Answers
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Posted on Feb 13, 2008
Lock the A/V ports
Yes you can, you have three diferent lock options:
'channel' this option allows you to lock or unlock particular channels.
'program' this option allows you to lockout a particular TV show.
'game' this option allows you to lock channel 3 and channel 4 plus the external inputs.
To activate the game lock on the tv you need to press the 'menu' key then press the down arrow till you get to 'lock' and press ok.You will then be asked to input a password, if it is the first time you have used the password then you will need to input a code of your choice twice to register it (write the password down and put it somewhere safe) Then you will be in the 'lock' menu so using the down arrow go to 'menu' and select it then se it to 'custom' you will then be able to select the 'game' option by arrowing down to 'game' and select it so that it shows 'on'. Your tv should now have locked out the external inputs etc. To unlock it you go through this procedure again just this time you select so it shows 'off' You can also select 'custom' in 'game' mode which will allow you to select which external inputs to lock which is useful if you have DVD players or other devices connected to your TV and is something for you to consider. Full details of above procedure are in the user manual page 32 - 33 under the heading Lock.
I hope this answers your question.
Regards,
James
Ps. Tell the kids it's my fault they can't play their games!!!!
Apr 23, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
How do I record onto a DVD from a video camera
connect camera to dvd on the dvd were you connected into will have (e.g EXT or AV 1-2 or 3 printed on it) you should put dvd on to that input mode by pressing input/saurce on remote then put tv on the input mode you watch dvd on
to record press on remote
Dec 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Cant unlock child lock on dvd player
Some require you to put in a code so your kids don't fu.k with it and turn it off.  Check your manual.
Oct 30, 2009 | Philips Universal PH301S Remote Control
Input is locked - code needed to unlock
If you have a Mitsubishi remote or the one that came with the TV, you can try the following.
Select the input.
When it asks for the code press and hold the QV button on the remote, then press the number 9.
That should unlock the input.
Then navigate through the menu and turn off the input lock, or any other locks that may have been set with the same key combo listed above.
I hope that this helps you with this issue.
Thanks for usning Fixya.
asnowman
Oct 17, 2009 | Televison & Video
My Mother has the VS-5003R big screen television that she purchased back in 1990. the television portion works fine but the ext-1 and ext-2 inputs are locked from a code that probably died with my father...
I have the same tv and same issue. I found chain of notes indicating that you can clear the lock by pressing 9-QV (two buttons) on the original remote at the same time. This works... however if you change the input again the EXT1 and EXT2 inputs will be locked again. It would be really nice if you can remove the lock feature completely.
Aug 07, 2008 | Mitsubishi Televison & Video
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
UNLOCK REGION CODE
you can't unlock a DVD player....
if it is a DVD drive for a computer you can watch movies with VLC because it ignores the region codes.
Oct 25, 2007 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Mitsubishi VS-45607 45" Rear Projection Television Logo
295 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
