Question about Rockford Fosgate 800.2 Car Audio Amplifier
800.2 well i ran it for a year like that and never had a problem till i blew the sub, i think when it blew the sub it frigged or blew something in the amp but i'll run the idea by one of my friends and see what he says. man i Appreciate your time man.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Well when you blow a sub it can definantely short your output fets in the amp.
Posted on Nov 02, 2009
  • 631 Answers
Does the amp power up?
Posted on Nov 11, 2008
What causes choke to engage on aVFR 800 98 its own? or simptons simular
sorry but no idea , and with no make,model,year I doubt anyone will
Oct 31, 2015 | Motorcycles
Porter-Cable compressor does not cut-off and pressure relief valve opens.
bad pressure switch or pressure switch port may be plugged up or could be wired wrong
Feb 26, 2012 | Air Tools & Compressors
My kenwood KAC-7204--- the wiring is hooked up right, I just got a 2000 watt max sub 1000 watt rms, i was running the amp in bridge mode and it ran for 1 day than it turned off. I checked it and the fuse...
when i was running my sub off bridge mode this kept happening to me. I ended up just running two subs and for some reason the fuse stopped blowing. i think there is something wrong with these amps.
Jun 04, 2011 | Kenwood KAC-7204 Car Audio Amplifier
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
I have a Magic Chef RB19HA-1A refrigerator that is freezing up requiring defrost every 10 days. It was turned off for 10 hours, and this has appeared. Ran fine for 5 years, till forced power loss. Has been...
timing is located with temperature control in frig section. Look up from beneath at the temp control you will see a hole with a slot screw driver adjustable knob inside it. rotate it till the frig shuts off. wait 30 to 40 minutes if it hasn't turn back on by itself the timing is bad. Also when you shut it off you can pull the back section out of the freezer, when you shut the timing off(by turning it with screwdriver) the defroster should turn on do not touch it the heat it puts off will burn you.
Jan 30, 2011 | Refrigerators
Top shelf of old sub-zero refigerator 60 degrees, bottom shelf OK
u may have a defrost problem it would be worth paying for the service call if something simple like defrost or a fan would still be more than 200 but worth it
Mar 18, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
My Subs blew out but I dont know why??
rewire the whole system with new wires,you could have a bad ground or wire try it first if that dont work rewire
Jan 08, 2008 | Jl Audio 12W3 Car Subwoofer
Rockford Fosgate 800.2 Car Audio Amplifier Logo
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
