Question about Bose Lifestyle 28 System
DVD I have an 15 year old RCA monitor and have it connected it to the Bose Lifestyle 28. Although I have had the system for a year, I have never played a DVD on it. CD's work fine. I have to switch a plug on the monitor to get the DVD to work and then I get a very strange picture. The images are shadowy and there are bands of static. Colors are quite distorted. I have tried two DVD's with the same results. Could you recommend a solution?
  • Bose Master
  • 19,396 Answers
First ensure that you are connecting DVD and sound system in the right way.
Check that there is no source of interference, like the subwoofer, or a power adapter too near to the video and audio cables.
Try switching the input channel on TV and see ifg you find DVD signal also on a different input channel, in that case connections may be also wrong.
Posted on Nov 09, 2008
  • 6,487 Answers
First thing to try here it to use a Lens cleaner so we can make sure that this is a problem with a dirty lens of your player, then fater that using a lens cleaner check if its already working....
I have a bose lifestyle 28 system. The DVD/CD player is broke is there a way to replace the receiver without buying and new system?
You should be able to connect another external DVD/CD player into its' auxiliary connection if it has one..
Dec 14, 2010 | Bose Lifestyle 28 System
DVD drawer will not open - stuck dvd inside
My only suggestion is to press and hold the eject button for a period of time (15 - 30 seconds). This might unlock the drawer. If not, I would contact Bose Customer Service directly.
May 15, 2010 | Bose Lifestyle 28 System
Our BOSE system has been working great for years and years. We recently moved, set up the system, and now the system has been very moody reading DVDs and CDs. It will take sometimes several minutes to...
I had the same problem with a Lifestyle 35 system. Use a DVD lens-cleaning disk, followed by the latest firmware disk from Bose. This should clear up the problem.
Jan 01, 2010 | Bose Lifestyle 28 System
I connected my bose lifestyle28 (correctly I suppose). What's the way to hear tv sound in bose ? When I push TV on the remote it doesn't work ! When a DVD works, beverything is right
You probably have the RCA jacks plugged into the wrong jack located on the back of the television. They can be confusing at times.
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Aug 18, 2009 | Bose (321GS) System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
I have a Bose Lifestyle 28 and want to hook my ipod up to it.
if there is a rca input available you can go to a local electronics store such as radio shack and pick up a rca MALE to 1/8 MALE cable
Feb 03, 2009 | Bose LIFESTYLE 28 Series III System
(Bose lifestyle 28) DVD picture is distorted, shadowy and difficult to discern
Try the settings setup and adjust the brightness, video format, or video black level. If you're using component connections then adjust the video output. You can scroll system setup through the remote control settings button.
Nov 10, 2008 | Bose Lifestyle 28 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Bose Lifestyle 28 System Logo
26 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
