Question about Philips Senseo HD-7810 Coffee Maker
Decreased output from Senseo
We have had our senseo for over 2 years, and love it. Recently, though, the 2-cup dispense is noticeably less than before. We're going through more pods to make the same amoung of coffee, and we figure there's buildup somewhere in the system. Any way to blow this ****** out?
I'm thinking it needs to be "Descaled" Heres info from Senseo.com:
Does my Senseo® appliance need to be descaled? Yes. Descaling is an important element in Senseo maintenance. It should be done at least once every three months, up to six times a year!
Keeping your Senseo free of scale will:
  • Ensure you have maximum cup volume
  • Ensure you have maximum coffee temperature
  • Make your Senseo produce less sound while brewing
  • Prevent your Senseo from malfunctioning
  • Prolong your Senseo's life.
The descaling process takes about one hour and should not be interrupted. Only a descaling agent based on citric acid can be used safely in the Senseo. Other agents, including vinegar, may damage your appliance or not remove the scale entirely. If the procedure is not performed correctly, scale residue may remain in the machine. This causes scale to build up more quickly and may cause permanent and irreparable damage to the machine.
For the right procedure to descale your type of Senseo, see attached document.
(links to attachment at the bottom of this page:
http://www.senseo.com/senseous/Templates/NonAuthenticated/FAQs.aspx?NRMODE=Published&NRORIGINALURL=%2fen%2fSenseoUS%2fServiceAndSupport%2fCoffeeMachineQA%2f&NRNODEGUID=%7b5584237E-F754-477A-BDFE-52A5DC85D35C%7d&NRCACHEHINT=NoModifyGuest#a23
Posted on Dec 15, 2008
Senseo HD7832 Calc Cleanup
This model of Senseo suggest cleaning once every 3 months, preferably 4 to 6 times a year.
I suggest to download the user manual from Philips for your model and to follow the procedure described.
Jun 12, 2009 | Philips Senseo HD7832 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
My philips senseo new generation won't open I suspect a vacuum-problem but don't know how to solve this can you advise me?
Eureka! I have solved this problem.
Disconnect your Senseo from the power. Take it to the sink. Hold it upside down and put hot water in the coffee outled. In less than 30 seconds the senseo will open.
The problem with Senseo is that - especially with coffee holders for 2 cups and chocolate - after making the coffee, the pod holder and the pod cool down. This creates an underpressure, that prevents you opening the Senseo. Hot water will increase the pressure and then you can open the senseo very soon.
This solution was found in despair after struggling with all the complex tool involving (knives, pumps, etc.)
Let me know if it works for you
Hans Beers (hansbeers@zonnet.nl).
Mar 26, 2009 | Philips Coffee Makers & Espresso Machines
My Senseo coffeemaker 7810/15 leaks water out of the spigot all over the counter.
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem. it is the seaing mechanisim at the top brewwing portion that is loose, either you are not closing it right or the pressure is getting too high forthe seal.
if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Jan 25, 2009 | Philips Senseo HD-7810 Coffee Maker
One coffee cup button switch not wotking properly after 6 months
Jan 24, 2009 | Philips Senseo HD-7810 Coffee Maker
Wont boil
Its no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Dec 21, 2008 | Philips Senseo HD-7810 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
Senseo making to much coffee
Try flushing the machine by filling the water tank with water and then pressing both the one cup and the two cup buttons at the same time (make sure to put a big enough bowl under the spout). If this doesn't work, give Senseo a call: 1-866-4SENSEO. They should be able to help! Good luck!
Aug 15, 2007 | Philips HD-7810 Espresso Machine
Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Aug 10, 2007 | Philips Senseo HD-7810 Coffee Maker
Philips Senseo HD-7810 Coffee Maker Logo
1,029 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
