Question about Quantum DLT 8000 DLT Tape Drive
Quantum DLT8000 Drivers not installing properly
Something strange going on with the installation of the drivers on my DLT8000. I'm able to use the xTalk program to run tests and stuff on the tape drive from windows so I know it's working properly. However, this is what the device manager says:
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
and it shows the little red exclamation point. Getting to this spot was difficult because of some issue with the INF file which (I guess) I was able to fix via this blog post:
http://www.loosewireblog.com/2006/07/how_to_fix_a_br.html
I added the [ClassInstall32] to the very end of the INF file that came with the downloaded drivers from the Quantum website. I was able to determine that the key name for this type of device is:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
and sure enough, there is a subkey 0000 which contains all the info about my tape drive.
This is what my setupapi.log file is showing:
#-199 Executing "C:\WINDOWS\system32\rundll32.exe" with command line: rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{A270A48C-25F4-4B08-8975-00D9D0356FF2}
#I060 Set selected driver.
#-019 Searching for hardware ID(s): scsi\sequentialquantum_dlt8000_________0257,scsi\sequentialquantum_dlt8000_________,scsi\sequentialquantum_,scsi\quantum_dlt8000_________0,quantum_dlt8000_________0
#-018 Searching for compatible ID(s): scsi\sequential,scsi\raw
#-166 Device install function: DIF_SELECTBESTCOMPATDRV.
#W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device.
#W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device.
#I022 Found "SCSI\SequentialQUANTUM_DLT8000_________" in c:\documents and settings\mike\desktop\dltdriver\QntmDlt.inf; Device: "Quantum DLT8000 Tape Drive"; Driver: "Quantum DLT8000 Tape Drive"; Provider: "Quantum Corporation"; Mfg: "Quantum"; Section name: "qntmdrv_Inst".
#I087 Driver node not trusted, rank changed from 0x00000001 to 0x00008001.
#I023 Actual install section: [qntmdrv_Inst.NTx86]. Rank: 0x00008001. Effective driver date: 10/19/2006.
#I063 Selected driver installs from section [qntmdrv_Inst] in "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf".
#I320 Class GUID of device remains: {6D807884-7D21-11CF-801C-08002BE10318}.
#I058 Selected best compatible driver.
#-124 Doing copy-only install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030".
#E366 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn, user said ok). Error 0x800b0100: No signature was present in the subject.
#W187 Install failed, attempting to restore original files.
#E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject.
#-024 Copying file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" to "C:\WINDOWS\system32\DRIVERS\QDLTx32.sys".
#E362 An unsigned or incorrectly signed file "c:\documents and settings\mike\desktop\dltdriver\QDLTx32.sys" for driver "Quantum DLT8000 Tape Drive" will be installed (Policy=Warn). Error 0x800b0100: No signature was present in the subject.
#-166 Device install function: DIF_REGISTER_COINSTALLERS.
#I056 Coinstallers registered.
#-166 Device install function: DIF_INSTALLINTERFACES.
#-011 Installing section [qntmdrv_Inst.NTx86.Interfaces] from "c:\documents and settings\mike\desktop\dltdriver\qntmdlt.inf".
#I054 Interfaces installed.
#-166 Device install function: DIF_INSTALLDEVICE.
#I123 Doing full install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030".
#I163 Device not started: Device has problem: 0x27: CM_PROB_DRIVER_FAILED_LOAD.
#I121 Device install of "SCSI\SEQUENTIAL&VEN_QUANTUM&PROD_DLT8000&REV_0257\4&156FABA9&0&030" finished successfully.
That #I163 error is probably what the problem is but I don't know what to do now... Any help is greatly appreciated.
  • chrisrun May 11, 2010
    Are there any answers for this problem?
    Any answer to this problem?
2 Suggested Answers
JaxPlanet
  • 922 Answers
SOURCE: Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Posted on Aug 11, 2009
Quantum pc camera qhm 500lm driver free download
I WANT TO INSTAL PC CAMERA QHM500LM TO MY PC, I LOST MY CD, PLEASE PROVIDE DRIVERS
Jun 04, 2012 | Quantum GoVault Cartridge With Docking...
What to do to install driver of quantum qhm100lm
Get onlineand got to www.google.com In the google search box type: "DellSupport" or "Quantum Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.You might also try Driver Guide.http://www.driverguide.com
Apr 23, 2012 | Dell LATITUDE NOTEBOOKS E6510 CI5266 156...
My model r/100 Quantum
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Nov 30, 2011 | QPS QSIPBL2 Network Camera
Drivers are not installing
it is the problem your oparating system you need instal new windows not repear then solve your problem
Jul 21, 2009 | Intel D945GCL Motherboard
I have no cd from my quantum web cam to install drivers
i have a quantum qhm 100 - lm webcam as iam looking for drivers for vitsa,can u people help me on this with the drivers and help topics
Apr 13, 2009 | Computers & Internet
Drivers download
Hard drives do not have an installation CD unless you are referring to Windows installation CD and installing Windows on the hard drive/
Dec 07, 2008 | Quantum Fireball Plus AS (QMP30000AS-A) 30...
QHM500LM USB PC CAMERA DRIVER SETUP NEEDED QUANTUM... how can i install webcam drivers QHM 500-LM
i have no software quantum qhm500lm usb web cam.driver. plzzzz help how can play my web cam. plzzz guide me
Nov 16, 2008 | Creative Labs WebCam Live!
Your offer for driver interests me
just go to the company site and download the latest drivers...k
Aug 07, 2008 | QPS QSIPBL2 Network Camera
Scsi tape drive not recognized on the library
Please check your firmware on the tape drive. Update with X-Talk software that can be downloaded from www.quantum.com.
Apr 28, 2008 | Computers & Internet
Quantum DLT 8000 DLT Tape Drive Logo
245 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
