Question about RCA HD56W66 56" HDTV
RCA HD56W58 I read your help with the RCA projection TV. And that the problem usually is the HVT and HVD. Did you replace these yourself? I found the parts online, and was wondering how difficult it would be to replace them myself. Thanks hdluvrs
RCA HD56W58 Rear Projection TV quit today. Resistor burnt up r14705. Power light goes on and high pitched noise but no picture or sound.
Posted on Jan 21, 2010
  • Kevin Kohrt Nov 18, 2014
    I found the parts needed to replace but felt the repair cost wasn't worth fixing compared to getting a newer (less obtrusive lcd TV).
    I really liked the HD card option with the RCA model though, eliminating the need for a cable box ( and extra remotes, I'm surprised more models don't have that option ( the Cable companies probably paid them not to offer it ). So it was a good TV for about 10 years.
    I found a repair video to replace the resistor with a soldering iron on You tube but ended up replacing the TV instead.
    Hope that helps.
    KK
TV is blurry and the red and green look as if the picture is in 3d and I need glasses. Can I fix this myself?
There is almost nothing that can be fixed by yourself if your not trained in high voltages and advanced circuitry now days. This sounds like it could be your color guns going bad or the power supply.
This set also has an issue with The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.
Jan 12, 2011 | RCA HD56W58 56" HDTV
How to connect a RCA HD56W58 56" TV to your cable box we have a dish network box and the only thing on the screen is input output please help
Try this link it should have all of the troubleshooting for this type of issue.
http://www.dishnetwork.com/SupportSection/video
Daniel Busa
DISH Network Customer Service
Dec 16, 2010 | RCA HD56W58 56" TV
Shows 3 screens all Different colors overlapping
This tv have a problems known as a convergence problems,it dead.The tv convergence board,require 2 STK convergence ICS and some or all it resistors to replaced to solved the tv convergence picture problems.The shop will,cost u $300-350 for parts and labors.
Oct 07, 2010 | RCA HD56W58 56" HDTV
I need to locate a replacement deflection board for my RCA HD TV part #267147R
I will need your old board as a trade in core, then a new board is $325.76 plus Shipping & Handling E mail:Cheese City T.V. Service at dmftrucker@yahoo.com Thank You
Nov 18, 2009 | RCA HD56W58 56" HDTV
BLOWN FUSE
Hi! i suggest that you do parts testing to sort out the problem.
Sep 21, 2009 | RCA HD56W58 56" TV
Channel banner burned into display
All three color lenses may need replaced and if thats the case you might want to consider buying another tv
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns on can hear sound then shuts down.
Did you check the high voltage transformer and the high voltage splitter (distributor). RCA HVT is known for going bad. i have the part number for both if needed. 5520-559-5774 john
Aug 14, 2008 | RCA HD56W58 56" TV
RCA model hd56w58
the part number for the high voltage transformer, according to another post for this tv is 258512. See below:
noavatar_s.gif jdenton77
Rank:nonexpert_s.gif Apprentice
Rating: 85%, 1 votes
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv
Jul 08, 2008 | RCA HD56W58 56" TV
RCA TV
ok is this s hd56w66 or hd56w58? if its a 56w58 then it is a atc321 chasis there has been some issues with the splitter and defecllection boards with that unit
Mar 23, 2008 | RCA HD56W66 56" HDTV
RCA HD56W58 Troubleshooting
Yes, i had the same issue. High voltage trans. and the HV distributor (splitter) goes bad on there tv, they are known for that. I have the part numbers for the HVT p/n 258655 and HV distributor(splitter) p/n 258512. The two p/n are for HD56W58 proj. tv.
Jun 27, 2006 | RCA HD56W58 56" TV
RCA HD56W66 56" HDTV Logo
393 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
