Question about Amana ACF3325 Gas Kitchen Range
Oven will not go on Bake but it will broil.
My oven will not heat up when turned on to any temp on Bake. It will cook on broil only. Please help
SOURCE: Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
Posted on Dec 01, 2008
SOURCE: oven bake does not work properly
check the selector swich and thermostat.
Posted on Dec 07, 2008
  • 6 Answers
SOURCE: oven not lighting on Amana model agds902ss
Posted on Dec 24, 2008
SOURCE: F2 amana acf4215ac
amana oven does not comeon
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: Amana Oven Issue
If you have an Amana range that allows heat to escape from the ranges/ovens when used in their intended manner and is causing irreparable damage to other components or the ranges/oven, including but not limited to, the units’ control board. This problem can discolor the units, diminishing their value and compromises the ability of the ranges/ovens to perform in their intended manner.
If so, this on going problem poses a significant safety risk to their users and property. I know many of you are frustrated and many of you have complained to Amana and have been told that, “There have been no complaints or that the problem does not exist”. Well they won’t be able to say that any more if the thousands of us come together as one and voice our concerns and complaints.
If you would like to be heard and possibly have your range replaced or fixed please send me an email of your existing problem along with your units’ serial number and model number and together we will be heard.
Posted on May 01, 2009
  • 1891 Answers
SOURCE: the oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Posted on Dec 23, 2009
0 characters
1 Points
Was cooking I'n oven. Heard a big pop sound and saw lghtning I'n tne oven. Now oven will heat a little but won't cook or broil ?
That sounds like the heating element went out when it first goes it could look like a lightning strike. Replacing the bake or broil element ,depending which one was on at the time will fix your oven. If you were baking replace bake element if ya werebroiling replace that one.
Reply with EXACT model number and i'll give ya the part number
Aug 27, 2011 | Frigidaire Kitchen Ranges
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Oven heating on bake
yes both elemnts do initially come on to get unit up to temp ( a bake boost) the lower elemnt then cycles on/off to maintain temp.. that is normal operation
Nov 11, 2008 | Kitchen Ranges
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Amana ACF3325 Gas Kitchen Range Logo
59 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
